Oil leaks
Old 02-23-12, 11:06 PM
  #31
GS714
GS714's Avatar
Default You probably mis-read/understood my post
Originally Posted by sam12345
Not very good advice. On my Toyota Avalon my water pump froze up and then my timing belt ripped to shreds. All this happened within a few minutes from each other (the strain of the non rotating water pump made the timing belt fail) luckily the Avalon is a non interference engine but if this would have been a gs I would be redoing the heads and who knows what else. Now ask yourself, is this really worth not changing a $50 dollar water pump when you are changing your timing belt. Penny wise and pound foolish is what not changing the water pump would be!
Correct me if I am wrong, the water and the timing belt are driven together in the Avalon? I think most front wheel drive car are designed like that. Space constraint maybe, who know? For the GS300's case, I was surprised to see that the water/P is driven by the serpentine belt. When I first bought the car, I said, oh man the timing belt and water pump job, that is big buck rite there. After driving lot and lot of front wheel drive car, I said those two are Tango Together. $$$$ at the dealer or $$$ at local garage. I stumbled on the a post in here, can't remember where. The individual within the post said you can do the Timing/B and the W/P together or separately.
Anyway, I just did the timing belt and the water pump altogether this passed weekend at 98K. I looked at the Timing/B and It still have lot and lot of life to it. I am not making any suggestion folks. It's your car.
Old 02-24-12, 04:35 AM
  #32
sam12345
sam12345's Avatar
Ok, I did not know that. When I bought my gs I went to Portland to get it. The car had 156000 on it and I did not want to risk ithe timing belt breaking on my 1800 mile trip back home so I had someone change the belt rather than doing it myself like I normally would. The car had the original timing belt by the way. The guy changed the water pump also and he told me it was leaking a little. The previous owner had put the green coolant in the car rather than the Toyota red stuff so I don't know if that reduced the longevity but apparently the pumps life is around 160k. Another reason to change it. And yes you are correct on the Avalon the water pump is driven by the timing belt, that is why the pump freezing made the belt fail.
dbui
RX - 1st Gen (1999-2003)
06-03-15 05:37 AM
itztwinki3
09-08-14 07:31 AM
itztwinki3
08-11-14 11:53 PM
randee973
02-20-12 04:12 PM
Rippaflow
03-23-09 06:12 PM
Quick Reply: Oil leaks
