oil leakkk !
Old Feb 8, 2012 | 05:53 AM
randee973's Avatar
randee973
Default oil leakkk !
bad valve cover gasket ? or what ?
Old Feb 8, 2012 | 07:14 AM
Vegas's Avatar
Vegas
Cam Seal?...
Old Feb 8, 2012 | 07:16 AM
LuxuryGS3's Avatar
LuxuryGS3
Yeah check cam seals.
Old Feb 8, 2012 | 08:39 AM
randee973's Avatar
randee973
yep valve cover gasket is shot.. so ima go ahead and do cam seals and crank seal *front*
Old Feb 8, 2012 | 10:40 AM
GS4_Fiend's Avatar
GS4_Fiend
When valve cover gasket leaks, dont just change the gasket, change the pcv valve too.
Old Feb 8, 2012 | 10:55 AM
LexiBlue's Avatar
LexiBlue
valve cover gasket or cam seals and also can be the vvti cam gear splashing on the timing belt i had that same issue and it was my vvti cam gear put in a new one with all new seals and waterpump and timing belt.
Old Feb 8, 2012 | 11:06 AM
SaiyanGS3's Avatar
SaiyanGS3
Let's use periods next time ok buddy lol. I had to re-read this a couple of times.
Old Feb 18, 2012 | 12:59 PM
randee973's Avatar
randee973
i got the valve cover gasket now .. where can i buy the cam gasket ..
Old Feb 18, 2012 | 01:15 PM
randee973's Avatar
randee973
ok correct me if im wrong...
i have the following parts
valve cover gasket w. rings for spark plugs
camshaft seal
crank case gasket
crank shaft seal
timing belt cover seal and gasket
does that cover the areas of any possible oil leak (gaskets) ? or am i missing anything
Old Feb 18, 2012 | 06:58 PM
GS300LUV's Avatar
GS300LUV
Default Same problem.
I have the same leak. I removed the timing belt cover and it was soaked with oil. So Im going to try the valve cover seal first. Im not sure how to do the cam seals yet. So once i find out how to do it here on CL i will attempt it. I have too add a QT of oil every 4 or 5 weeks. So I'm hoping its not the fwd crank seal. Those little drops of oil on the garage floor is quiet annoying. Good luck finding and fixing your leak.
Old Feb 19, 2012 | 06:38 PM
randee973's Avatar
randee973
thanks bro keep me posted im ordering all the gaskets and seals today hopefully get to it by the weekend
Old Feb 19, 2012 | 06:39 PM
randee973's Avatar
randee973
even tho the valve cover is leaky.. mine is leakin towards the front so im guessin the cam or crank seals need to be replaced
Old Feb 19, 2012 | 08:20 PM
Och's Avatar
Och
Crank seal is below. All you need is two valve cover gaskets (L&R) and two cam seals. Might as well do the crank seals too, since you'll be removing the timing belt to access cam seals.
Old Feb 20, 2012 | 10:50 AM
defloc527's Avatar
defloc527
looks like you got everything covered man.. hope it solves the problem
Old Feb 20, 2012 | 04:12 PM
randee973's Avatar
randee973
thanks for the feedback guys
saleen90
Jan 6, 2014 08:39 AM
FrankT
Mar 12, 2012 10:13 PM
ralsty
Oct 31, 2008 10:39 AM
aaron30
Mar 18, 2008 10:10 AM
vtec-this
GS - 1st Gen (1993-1997)
Mar 10, 2008 12:27 PM
