Weird HVAC problem. Drivers side blows cold only. Not servos or doors.
Here is a weird one. The left vent blows cold air and the right vents operates normally. Has codes 21 and 24. I performed automatic test and all three servo motors operate correctly. I then drilled a hole on both sides of the heater box and saw the air mix doors move when the temperate switch was moved. The volume of air seems ok. The only thing I can think of is half of the heater core is plugged or there is a restriction blocking air to the heater core.
I have some other pieces of information. The a/c filter door is missing since I had it, which is over 15000 miles. It has green antifreeze. The white lower ducts has traces of rusty water. The prior owner had an a/c compressor installed. The internals came apart. I installed another one and flushed the A/C system.
I appreciate any advice
say
if u would search you would already have the answer to your dead servo issue...and you could have the answers to this ? also
BTW servos DONT show on the diagnostic codes....codes 21-24 are solar/light issues probaby cause OP you did this in the garage or at night
change your thermostat half closed/open
this is probaly the culprit - please reply back if this fixed the issue
if you temp guage is not all the way to the half way mark that will
be the cause
be the cause
air mix servos
I checked the air mix servo visually - it moved. I thought the air mix door might have been broken - that is why I drilled the hole to visually check the door. I can easily reseal a small hole. The heater core is hot at both inlet and outlet. Coolant temp gauge is at the middle.
Is there any other doors before the heater core.
Perhaps I can back flush the core, change coolant and thermostat.
Thanks for any other input.
coolant issue?
thats sounds like a good plan your eliminating "all coolant issues" that may be
the culprit - i still think it just the theremostat because if you have never
changed it in 150k miles well it maybe stuck which is good cause your not
overheating. why dont you change the thermostat 1st and see if that works
if not then do the other steps you plan to do anyways? keep us posted he on CL.
What do i know though, i only manage a HVAC supply house
I didn't have any clogs, every time mine gets low I can tell because one side is considerably warmer than the other, as if the passenger had the heat halfway on and driver with max a/c. I put a gauge on it and it show's borderline levels (basically just over the line for "low", hence some cool air (but not as cold as it should be) coming out), throw a little refrigerant in it and it's back to new operation again within seconds with very cold air out of both sides. I know it sounds odd but that's what it's been every time in my case, it's also repeatable in my instance, every time it's happened it's been borderline low on refrigerant. Throw a gauge on it, you should be able to tell right away if it needs to be charged.
But.....After reading the OP's first post it seems as though he has a different problem though, mine will only blow cold on one side (with the A/C on max low, summertime for instance), he seems to be having the opposite problem, one side of his is blowing cold air when he want's it to be warm (so I'm assuming he has the heat on max). In other words, his problem is the opposite of mine, and with heat, which wouldn't matter if the refrigerant was low or not.
Either way, if anyone ever has the problem of only one side cool in the summer and your servos are working, get a gauge and check your refrigerant, it's probably borderline too low.
blows "cooler" on one side
yes the gentleman is correct its the opposite case - i have the same issue
we want hot warm air from both side but for some reason it blows "cooler" on
one side hence i feel 100% its a stuck thermostat.
http://www.cliplight.com/automotive/...tID=16&catID=4
i personally have used it and we sell it.....seals small leaks and should work out well for you
Have the refrigerant level checked, when it gets low one side blows warmer than the other, my car did the same thing. Had the system recharged and it was back to cold all the way around
that's actually not true Damian....it might have worked for you (and i will explain my theory as to why in just a sec) BUT if your system is low when it circulates BOTH sides will blow warm. (i would think your probably had a clog or something stopping up part of the evaporator thus causing one side to be cool and one side to be luke warm and when they added freon it pushed the particles through thus clearing your "jam" this would be especially true if they recovered it and then recharged it)
im gonna bite my words damian....the bolded is true. i had this issue and after rechecking my servos, i put my gauges on and i was indeed low. im still curious by this as this is a closed system and if one side is cooling (since the car only has one condensor) then the other side should be cooling also, but it wasnt....i put the gauges on and it was low, recharged her and all is good again but i will keep a eye on it. if it went low from 5 years ago (when i last put some R414B in it) i seem to have a uber small leak (or i hope thats the case) and may end up using some cliplight to "seal" it if it persists
