Wheel width/offset/size and tire fitment Q&A thread
Old 05-23-11, 05:48 AM
  #76
ZippyGuy
ZippyGuy's Avatar
Originally Posted by YaKuZa_GS
Do people usually start typing without thinking about what they're going to say? Think about what you just said and slap yourself. I mean really, why do you think people roll/shave the fenders and stretch tires for in the first place?
Funny, but true. I don't think the question was fully thought out or maybe the intent wasn't commuicated.
The widest wheels you can safely run without modifications to the wheel wells are f20X9 et42, r20X10 et44. My offset might be a little of off but if you speak with a wheel reseller like D2Autosports they can get you headed in the right direction.
Old 05-24-11, 06:19 AM
  #77
Bippu147
Bippu147's Avatar
^NOT TRUE
I ran a 10.5J + 39 last year with no modifications to the rear, and it looked like it still needed a spacer
Old 05-24-11, 08:33 AM
  #78
ZippyGuy
ZippyGuy's Avatar
Originally Posted by Bippu147
^NOT TRUE
Actually, true. The OP mentioned he wanted to not make any fender modification. If you're running tires that are in spec (25.75 - 26.15 inches overall diamter) with the appropriate aspect ratio you're at the limit at 10. You can go up to a 10.5 rear if you run tires smaller than spec (stretched).
Old 05-24-11, 08:59 AM
  #79
J$mooth23
J$mooth23's Avatar
Just ordered some Works, can't wait! My question is, if my fronts are rolled and rears shaved will i need to do any fender flaring or pulling if I'm running:
19x9.5/10.5 +22??
225/35 f and 265/30 r
Old 05-24-11, 01:38 PM
  #80
Sonic_RC
Sonic_RC's Avatar
Incorrect 17" OEM size is only 235/45R17 which is only 25.33 OD. and the OEM 16" is 26.16. So with that being said if you go with a 285/25R20 and its 25.61 OD however is a pretty expensive size compared to 275/30. But 275/30 on a 10.5 you can't even call a stretch on 10.5" It really depends on what brand you go with. some fit wider than others.
19x9.5/10.5 +22??
should be fine, no pulling required but i would use a skinnier tire like a 235/35 or 245/35.
Old 05-24-11, 03:15 PM
  #81
UpstateLex
UpstateLex's Avatar
I've got Work wheels coming in too. 18X9 + 30 18X10 +38. fronts should require a slight roll? what size tires should i be going with here?
Old 05-24-11, 07:46 PM
  #82
Sonic_RC
Sonic_RC's Avatar
You may need a minor roll in the front but it depends on how low you are. You should be fine
Front 245/40R18 / Rear 275/35R18
Old 05-26-11, 11:48 AM
  #83
UpstateLex
UpstateLex's Avatar
thanks for the input yakuza, bigger sidewall up front tho?
Old 05-26-11, 08:15 PM
  #84
Sonic_RC
Sonic_RC's Avatar
The sidewall height of both the tire heights are the same
245/40 = 40% of 245mm = 110mm
275/35 = 35% of 275mm = 96mm
so technically 4mm shorter which is nothing.. if you want to be more exact you can go 235/40 which sidewall height should be 94mm. But 245's fit better on 9"
Old 05-27-11, 08:31 AM
  #85
UpstateLex
UpstateLex's Avatar
Thanks for the detailed explanation. 245 in front will require more of a roll I suppose? 235 would be a stretch? Thanks yakuza
Old 05-27-11, 09:57 AM
  #86
Sonic_RC
Sonic_RC's Avatar
Bingo. The 245 will pretty much sit square on the tire. the 235 will only be a very minor stretch
Old 05-27-11, 04:56 PM
  #87
UpstateLex
UpstateLex's Avatar
Really appreciate it. Can't wait. It's been 7 weeks only a few more to go!
Old 06-08-11, 06:58 AM
  #88
diamondlou
diamondlou's Avatar
Default Will these fit?
Size: 18x9 Centercap Size: Large (2-1/2")
Back Spacing: 6.4" (164mm) Offset: +36mm (1.4")
Bolt Pattern: 5x4.5" (5x114.3mm)
Stock Suspension for now....
Thanks!
Old 06-08-11, 12:46 PM
  #89
vipXjunky
vipXjunky's Avatar
would 245/35 cause any problem with a minor rolled rear fender?
rim specs: 10.5 +22
Old 06-08-11, 01:30 PM
  #90
SPRTNYDSN
SPRTNYDSN's Avatar
XXR 526
20x9 offset +35 and
+15 offset 20x11
Donz Montanas
20x8.5 +20 and
20x10 +25
My car is going to a bodyshop soon...can't afford wheels now but these are the two that I narrow down to. Without pulling fenders (only shaving) what tire size can I get away with(I don't mind stretched tires either)? I'll be on BC extreme drop coilovers, I'm trying to get fender to lip ratio. Thanks in advance!!!
Quick Reply: Wheel width/offset/size and tire fitment Q&A thread
