GS300 OIL change urgent plz help
Old 06-07-10, 05:06 AM
edinburger
edinburger's Avatar
Default GS300 OIL change urgent plz help
hi guys this question has been answered many times i did look around for previous posts but didnt find precised answer.
plz help i'll ask in order my cars is 1998 mk2 GS300 135k miles
1. 10w40 or some thing else ?
2. fully synthetic or semi synthetic ?
3. car takes 5.5L or 6.5 liter ?
4. brand matters ? shell, halfords, mobil 1 etc
many thanks guys
AJ
Old 06-07-10, 05:30 AM
YviE
YviE's Avatar
Hi,
I also have to do the oil change on my GS300.
1. 5W30
2. synthetic (not semi)
3. somewhere between 5.2 - 5.5L depending on the size of your oil filter
4. Popular brands are Mobil1, Castrol and Royal Purple
I've decided to go with Castrol Edge 5W30.
Old 06-07-10, 08:20 AM
vwynn
vwynn's Avatar
many thanks guys
AJ
heres my input..
1) 5W30
2) Personally Full Synthetic.. but its personal Pref... (you can do Regular conventional if you want.. or semi syth or full syth.. your money your car)
3) buy a 5 Quart Jug and 1 extra quart in case you need to top off
4) Personal Pref. Castrol - Mobil 1 - Penzoil - Royal Purple - Amsoil - Enyos
edit: Dam i read you're from Scotland... so iono whats the quart to liter conversion but hopefully they sell the big jugs there
Old 06-07-10, 08:25 AM
YviE
YviE's Avatar
A quart is a bit less than a liter I believe.
Old 06-07-10, 08:47 AM
Rich23
Rich23's Avatar
10W30... (Remember mileage plays a key role here)***
mobil1 SYNTHETIC
approx. 5.5 (I have a 430 and it took 6.5 qts)
Mobil1 has been good to me thus far... Castrol should be just fine as well...
Old 06-08-10, 11:34 AM
edinburger
edinburger's Avatar
cheers guys.
if i go for 10w/40 fully synthetic would that be ok.
my car has 135k miles on clock
ta
Old 06-08-10, 12:34 PM
Mr Jokster
Mr Jokster's Avatar
I've heard that if the car has been using regular oil and is switched to synthetic after many miles... It will leak through the gaskets; does it happen all the time? No, but it happens often. I believe thats my problem but I deal with it since its only a very minor drip and I never go low. My personal fav is Castrol or Mobil 1. As for weight, has to do with weather, during colder climates/seasons you want a thiner oil. During hotter weather you want a bit thicker so it doesnt heat up. I do 5w30 for winter and 10w30 for summer but thats for California caca weather.
Old 06-12-10, 04:21 PM
edinburger
edinburger's Avatar
thanks guys finally went for 10w/40 semi synthetic mobil 1
cheers lads
Old 06-12-10, 08:42 PM
Big Mack
Big Mack's Avatar
Cool
How often? I ask because it's very rare now. It used to be an issue, but it has been years. I ran regular dino oil for years in another vehicle, and when it hit 75K, I switched to a high mileage synthetic. No leaks, no drips, no errors - even after 35K miles. This was 9 years ago. Oils certainly have not degraded since then.
Current DD, being a 4 banger, was definitely not treated to synthetics prior to me owning it. I have used synthetics for nearly 2 years now, and not a drop of oil has leaked.
I think you're on the right track. Unless you do a ton of extended high speed driving in high temperatures, though, 5W-30 should be fine pretty much all the time.
Big Mack
Last edited by Big Mack; 06-12-10 at 11:19 PM. Reason: Forgot the "not" in last sentence of first para of reply
Old 06-12-10, 08:47 PM
Mr Jokster
Mr Jokster's Avatar
Maybe cause its 'high mileage' oil and thats what took care of the problem? just a question/comment. I'm using regular synthetic... maybe thats problem
Big Mack
now that I think of it... Those were the weights I used on the drag car when it was streetable Drove the biatch to the ground!
Old 06-12-10, 08:58 PM
Big Mack
Big Mack's Avatar
Cool
Nope. I use regular synthetic in the DD and no leaks. Sounds like you had a seal that was going bad, and perhaps the higher flowing synthetic popped whatever was clogging the leak free?
Big Mack
Old 06-12-10, 09:31 PM
JeffTsai
JeffTsai's Avatar
How often? I ask because it's very rare now. It used to be an issue, but it has been years. I ran regular dino oil for years in another vehicle, and when it hit 75K, I switched to a high mileage synthetic. No leaks, no drips, no errors - even after 35K miles. This was 9 years ago. Oils certainly have degraded since then.
Big Mack
The reason why you may get oil leaks after switching to a synthetic oil is if your seals and gaskets are in bad shape to begin with. The equivalent weight of synthetic oil is still slightly thinner than the same weight in a conventional oil. Your car was probably already leaking oil very slightly to begin with, but not significant enough to notice. However, when changing over to the synthetic, the thinner viscosity of the oil caused it to start seeping through the cracks in the seals.
Old 06-14-10, 06:11 AM
gcam77
gcam77's Avatar
JeffTsai I sent you a PM.
roshanfiro
03-10-16 03:17 AM
RydinRuff
10-25-10 03:34 PM
istundra
10-07-07 09:12 AM
b1gredek
Maintenance
04-08-05 10:12 AM
Quick Reply: GS300 OIL change urgent plz help
