how to install led license plate lights??
i am not the handiest of people...but anybody have any instructions? thanks just bought the white led from wardenjp from ebay...
get a Cable Tie/Zip tie, 'medium' sort of size. It will fit perfectly thru the slots on the boot trim clips. Pull them out, you can then remove the trim.
you can then see where the bulb plugs are. they are held in by a twist and lock method, so you will need to twist them to unlock (as per usual with lots of bulb connectors) and the connecter and plug will come out.
you then pull the bulb itself out of its slot, and replace it with the warden bulb. The warden LEDs do have positive and negative polarity, so check the bulb is working before putting it all back together! what i mean by polarity is, it needs to be the right way round so if it doesnt work one way turn it aroudn and try the other.
thats it.
thats it.
iModerate
In the pic from Debonair (good job, BTW on that, mang) the ones North of the handle. I removed all 4, but you could probably do just the three to the right of the handle. It's a tight squeeze, but I didn't undo the handle at all. Got the scrapes and cuts to prove it!
Big Mack
Big Mack
iModerate
Big Mack
Big Mack
When I went back in and did my CCFL license plate lights and Dynamat I pulled the whole thing down.
