**HELP** 03 GS3: Passenger's Air Climate Differential
Old 03-23-09, 10:52 AM
Stiggz
Stiggz's Avatar
Default **HELP** 03 GS3: Passenger's Air Climate Differential
Hi all...
I dont have a clue why when i put the heater on, my passenger vents blow cold (a/c'ed) air...the problem persists in the all vents geared toward the passengers (the right-most vent in the middle of the dash and the vent closest to my passenger's door) including the rear vents in the center console. all driver oriented vents work and heat as instructed to but the passenger's vents dont. yes i know about dual climate control and thats not the issue...the problem is sporadic (in the winter when i actually used the heater) but did NOT work more often than it did...any help/suggestions on what the problem might be?
thanks in advance
Old 03-23-09, 11:53 AM
sakataj
sakataj's Avatar
check out my DIY...
https://www.clublexus.com/forums/gs-...ml#post4121280
u got a servo problem....
and try searching next time....many posts on this subject or u can use this link...its a good one
https://www.clublexus.com/forums/gs-...ou-search.html
welcome to the club
Old 03-23-09, 01:32 PM
Stiggz
Stiggz's Avatar
sakataj
Thanks for the help! this is definitely what i was looking for...
i tried to do a search but i didn't even know what to search for...just "A/C" but as you might know, about 5000 threads came up with that query...anyways, thanks for the write up...i'll try to DIY but i am really impatient with **** like this and would rather just buy the part(s) and take it to a pro to do it for me. I dont mind paying good money knowing that my **** is taken care of right...
Old 03-23-09, 02:04 PM
sakataj
sakataj's Avatar
Originally Posted by Stiggz
sakataj
no prob....n u can do it...i laid out the steps in my DIY for you...
bigrx
RX - 1st Gen (1999-2003)
11-14-14 06:03 PM
T8LEX
12-09-10 07:08 AM
aeropartz
Performance & Maintenance
16
12-22-09 02:12 AM
bg_281
11-28-07 08:48 AM
Quick Reply: **HELP** 03 GS3: Passenger's Air Climate Differential
