01-05 GS Headlight Alignment
Old 12-10-08, 06:42 PM
timgs300
timgs300's Avatar
Default 01-05 GS Headlight Alignment
EDIT: Added instructions and replaced dead linked pictures with new pictures. Debonair.
After adjusting the headlight in the vertical direction, check that the light has been shifted from the adjusted position in the horizontal direction.
  1. Inspect the headlights aiming. Do the following items before inspection:
    • Make sure the body around the headlight is not deformed.
    • Park the vehicle on a level surface.
    • Tire inflation pressure is at the specified value.
    • The driver gets into the driver's seat and puts the vehicle in a state ready for driving (with a full tank).
    • Bounce the vehicle several times.
  2. Adjust the headlight aiming.
    • Vertical Alignment - If the bubble is out of the acceptable range of the beam angle gauge, adjust it using bolt "A".
    • Horizontal Alignment - If the edge of the lens does not match the 0 mark, adjust the lens using bolt "B".
Last edited by Debonair; 10-06-16 at 06:24 AM. Reason: Updated instructions and pictures
The following 2 users liked this post by timgs300:
n1ck (06-05-18), nlbrownjr (02-19-22)
Old 12-10-08, 07:36 PM
TruPlaya26
TruPlaya26's Avatar
nice ...
Old 01-21-09, 12:57 PM
nanotech
nanotech's Avatar
Is there a PDF version of this? I would actually like to print it off and take it to the car with me to do it right. Plus I could have a copy for future references.
thanks...
Old 07-28-13, 02:06 AM
istundra
istundra's Avatar
good post bump
Old 06-27-14, 09:44 PM
aneidiaz
aneidiaz's Avatar
Bingo! I think I found out the problem to that little on and off annoying yellow light...
Old 05-09-16, 09:43 AM
AmanO
AmanO's Avatar
Any who has done this have pics?
Old 10-06-16, 06:25 AM
Debonair
iModerate
Debonair's Avatar
I have added text instructions and replaced the dead-linked pictures with new pictures.
Old 10-06-16, 06:43 PM
Mcon
Mcon's Avatar
I suscribe. I did it before myself, but is good to have this just in case if I forget something later.
Debonair
Old 10-06-16, 07:55 PM
RoguesGS
RoguesGS's Avatar
Thanks for fixing this Debonair!
Old 10-07-16, 11:17 PM
AmanO
AmanO's Avatar
Thanks for update. I assume this is the same for HID and Halogen.
Old 10-14-16, 07:41 AM
trinimoe
trinimoe's Avatar
Can this help with the auto leveling issue ��
JohnnyCake
05-05-23 06:09 PM
howiedoit
Lighting
07-20-07 07:25 AM
triplecore
09-03-06 06:42 PM
Quick Reply: 01-05 GS Headlight Alignment
