Resetting window motor?
Car was broken into and I had the window replaced. When I use the automatic roll up button now it goes all the way up then half way down. I have to hold the button down manually to get it all the way up.
Called the dealership and they said the motor would need to be reset. Is it possible to reset the motor myself?
I have this issue as well.. started after installing speaker and crossover into my door.. I've heard this can happen if the little flaps between the door and the window aren't in their correct position..
I had to replace the motors because of the same issue, they were damaged when the car was broken into. Check with a dealer or if you have a good indy that could save you some cash. Mine was about 425 for both windows at the dealer
Billy305
SC- 1st Gen (1992-2000)
05-28-10 09:11 AM
masboy
Maintenance
05-12-09 05:02 PM
turbosix
11-02-07 05:47 PM
