19's vs. 20's
Old 09-13-07, 11:34 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
As you may imagine, this is a topic of a lot of discussion in the past here on CL, here are a few threads to get you started I found using search
Threads on 18's or 19's
https://www.clublexus.com/forums/sho...hlight=18s+19s
https://www.clublexus.com/forums/sho...hlight=19s+20s
Threads on 19s or 20s
Threads on 20's and ride quality
https://www.clublexus.com/forums/sho...light=20s+ride
Don't forget about rubbing as well... not all experience it but some do.https://www.clublexus.com/forums/sho...light=20s+ride
Nice wheel guide
Chrome / Hi Polish
Polls in the voting booth
https://www.clublexus.com/forums/hall-of-fame-and-voting-booth/98821-did-you-would-you-upgrade-your-wheel-size-from-oem.html
https://www.clublexus.com/forums/sho...d.php?t=128050
17 or 18's just to be thorough
https://www.clublexus.com/forums/sho...d.php?t=162617
Hope this is helpful
Old 09-13-07, 11:36 AM
michael200
michael200's Avatar
Originally Posted by edouble
I love the horsepower that my GS400 puts out. I have been looking at wheels for it but as much as I want the car to look great, I don't want to take away from the performance. I currently have 16's on it. Does anyone know if there is a certain size I should go with if performance is my main objective? If so could you send me a link?
Thanks
Personally, 19 and 20 inch wheels look like crap on these cars, and actually screw up the performance, as well as usually causing tons of problems with rubbing, etc. Stick with the 16" wheels, the big wagon wheels are just a "fad", IMHO.
Old 09-13-07, 11:49 AM
4ntvings
4ntvings's Avatar
^^^wow, this kinda came from past left field...
Old 09-13-07, 12:04 PM
PushinLEX
PushinLEX's Avatar
Originally Posted by benzo555
Well I have a supra TT spare then I cut a custom wood crossbar and solved the problem. The supra TT spare weighs at least half of the full size just in case for those long trips.
Thanks for the info. I'd rather just use the cross braces and forget the spare. I wouldnt even use the spare with my aftermarket wheels. If I get a flat, GS is gonna get towed on a flat bed...AAA Plus
Oh yea, any pics of your Supra spare w/ cross braces? Thanks man.
Originally Posted by TruPlaya26
#1 The GS does not weigh 4,600 lbs. it weighs more around 3,700 - 3,800 lbs.
#2 The GS is classified as a luxury-sport sedan ...
#3 True taking weight off wheels is more effective than taking weight off the chassis, but reduced weight is reduced weight, and it helps either way ...
. I think the rule of thumb is every 100 lbs of dead weight on the car yields a .1 difference on the 1/4 mi.
The stock spare and jack weights a TON. Probably like 50-55 lbs for the whole setup. Plus I wouldnt even be using it.
Old 09-13-07, 12:09 PM
PushinLEX
PushinLEX's Avatar
Originally Posted by onedropz
weight reduction on a 4,600 lb car made for luxury?
anyways... if you take 1lb off the wheel it will effect your performance more than if you take 1lb off the chassis.
http://www.lexus.com/contact/pdf/1999/1999GSspecs.pdf
My car: 1999 Lexus GS300
Curb Weight = 3,638lb Where did you get the extra 1000 lbs from? The 400, surprisingly, weighs only 60 lbs more than a 300. So taking the spare and jack assembly out of your 400, will net you around the curb weight of a 300, without sacrificing basically anything.
Not to mention the added handling and gas savings (over the long run albeit), of weight reduction.
Old 09-13-07, 10:29 PM
edouble
edouble's Avatar
Thanks for the threds. I really appriciated it. By the way, it looks like you've built one hell of a car! Do you have any pics? I'd love to mess around with mine like that.
OaklandLex
SC- 1st Gen (1992-2000)
66
10-21-11 06:37 AM
mvallido
10-13-06 10:44 PM
alexamparo
GS - 1st Gen (1993-1997)
14
02-04-06 11:05 PM
mjr24
21
03-26-02 04:52 AM
socal
02-12-02 10:44 PM
Quick Reply: 19's vs. 20's
