Will a RX300 Steering Wheel Fit a GS?
I have a 2001+ Wood Steering wheel from a GS300 w/ E-Shift and the 2001 RX300 airbag combo on my 1999 GS400 w/ E-shift..complete bolt-on. I have an opening on the left side of the wheel were the stereo controls are supposed to be located (my wheel did not come with it) so that will have to be blocked off or the control added to the wheel,
If you want the anatomical "bulges" at 10 o'clock and 2 o'clock of the oem wheel, plus the new airbag with the chrome Lexus emblem in the center this is your only option at this time. The RX300 wheel will also bolt on but for 98-2000 GS cars you must use the RX 2001 single stage airbag. The air bag is definitely the more expensive piece since you are looking for a specific year; RX wheels are on E-bay all the time. 2001+ GS E-shift wheels are much more difficult to come by; especialy with the optional wood trim.
exclusive matchup
plug & play homeboy ! no mods, no cuttin', no solderin'....nada. bolt the thing on and be off.
single connector for single stage airbag...same connector as original airbag from 98-2000 GS.
You MUST use the 2001 RX300 airbag for this....it has a specific part number ; 45130-48040-C0....tho be prepared to spend some seroius bank if purchased new ( $800.00 list).
The factory wheel/airbag combo when installed on 98-2k GS looks exactly like a 2001+ GS300 with the optional ( $300.00) wood wheel/shifter with E-shift. The only thing missing on my car is the stereo/nav mode controls that are mounted on the wheels left side. I am currently working on setting this control up to handle a mp3 player I use in the car.
If you don't need the E-Shift controls just use a RX300 wheel.
exclusive matchup
and boy, having thsoe audio control would be nice! i always love to adjust audio on the steering wheel!
just keep your eyes open on E-bay. my own personal 2 cents........this makes the interior really standout. just look at a 2004 GS brochure for the interior shots....wow.
good luck
good luck
https://www.clublexus.com/forums/gs-...-retrofit.html
http://www.crutchfield.com/S-RLifX9N...l-Adapter.html
http://www.crutchfield.com/S-CMV8K9Z...s-adapter.html
DCTMS
RX - 1st Gen (1999-2003)
12-11-15 06:24 AM
kendre
07-20-04 06:45 PM
