need help with my radio
Old 10-23-13, 05:59 PM
3tcpower
3tcpower's Avatar
Default need help with my radio
I just got me a 93 gs and the radio turns on but the sound is really low ...I mean I have to turn the volume to max to hear some barely. So the guy I got it from told me they had someone install an different pioneer changer and after the guy did it the radio wasn't the same ever since. He says the sound comes and goes. So I looked at how the guy installed the changer and it was a mess plus he tapped into the antenna wiring for power smh it was crap. I took it out completely and said fock it lol now I want to know whats missing in the picture I posted and what are those connectors for.
Old 10-23-13, 08:54 PM
onelt1
onelt1's Avatar
If I am correct those two connectors go to the stock CD changer and thing missing, that bolts on top of the stock amplifier, is the stock CD changer. Hope this helps.
Old 10-24-13, 08:49 AM
3tcpower
3tcpower's Avatar
ok so that thing is just a stand for the factory changer! ok coo thanks bro now i don't feel as bad like it was missing something huge. well I'm guessing the high and low issue is the amp is faulty. guess i will be going with an aftermarket radio because the prices for these factory units are ridiculous
Old 10-25-13, 08:21 PM
houndawgbp
houndawgbp's Avatar
I just got my ride too bro. Your factory amp is shot. Mine was already bypassed. I'm routing wiring now to run a mtx sub with a kicker amp in our stock shelf location. I ran all new speaker wire to the door speakers and they sound fine now.
Old 10-26-13, 07:25 PM
3tcpower
3tcpower's Avatar
yes i will do the same thing...seems like the only option right now. what head unit you using?
Old 10-28-13, 04:12 AM
houndawgbp
houndawgbp's Avatar
Ooku touchscreen DVD player. Offbrand copy of pioneer
Old 10-28-13, 06:55 AM
3tcpower
3tcpower's Avatar
ok cool, i'm not trying to get no high end stuff anyways! plus thats the first thing people see when they walk by your car! thanks bro
Old 10-29-13, 06:34 PM
houndawgbp
houndawgbp's Avatar
Anyone have any idea how to run power wire to the trunk?
Old 10-29-13, 10:19 PM
Salcedo90
Salcedo90's Avatar
I ran mine on the driver side under the carpet
Old 10-30-13, 12:03 AM
houndawgbp
houndawgbp's Avatar
Where did you run the wire through the firewall? I can't find a grommet to feed it thru
Old 10-30-13, 08:56 PM
3tcpower
3tcpower's Avatar
just one of the other tasks that i have to deal with once i get to that point! haha since the fuel tank is back there i'm sure that area is sealed off.... but where there's a will there's a way!
Old 10-31-13, 08:56 AM
ProjektS13
ProjektS13's Avatar
Theres some predrilled holes capped off, you can see them once you get all the trunk trim crap out.
Old 10-31-13, 12:01 PM
houndawgbp
houndawgbp's Avatar
Any idea how to get thru the firewall?
Old 11-04-13, 04:06 AM
houndawgbp
houndawgbp's Avatar
I think I may have to drill a hole to feed it thru
Old 11-04-13, 03:43 PM
onelt1
onelt1's Avatar
I have heard that there is a grommet for the ecu on the passenger side. I drilled a hole and put a grommet in on the drivers side, where the firewall sheet metal meets the wheel well sheet metal.
Quick Reply: need help with my radio
