radiator/ ac condensor fans not engaging
Im having the same issue as this guy:
https://www.clublexus.com/forums/gs-...t-running.html
his thread was never really resolved; at the moment, my voltmeter took a crap. So i'm on the way to the store to pick up another multimeter. First i'm planning on checking to make sure that the wiring is receiving 12 volts or not. From there i plan on checking continuity on the fuses, and on the relay.
So if all three of those sources check out fine, what would you guys suggest next? thanks!
BTW just wanna verify, the correct relay and fuse are under the look labeled as RDI fan right? any others i should be checking?
:edit. found the problem, ill update in the thread
solution:
https://www.clublexus.com/forums/6705887-post6.html
solution:
soundquest
06-11-19 11:38 PM
GreenUCF20
07-06-12 11:07 AM
