Oil change.... 5, 5.5 or 6 quarts?
Old 05-26-10, 01:42 AM
Wald GS
O.C. Lucky Strike Fanatic
Wald GS's Avatar
Default Oil change.... 5, 5.5 or 6 quarts?
Hey guys,
I can't find my user manual and did an oil change today. I put in 5 quarts and it was perfect on the dip stick.
I could have sworn it was 5.5 quarts according to the manual or maybe even 6.
Thanks!
Old 05-26-10, 03:11 AM
mkiiisupra
mkiiisupra's Avatar
manual says 5.4 with a smaller filter or 5.7 with a larger one. Toyota makes 2 size filters for the 2jz.
Old 05-26-10, 08:47 AM
GS300 I6
GS300 I6's Avatar
i usually put 5.5.
Old 05-26-10, 03:32 PM
YupImJOee
YupImJOee's Avatar
5.5 with 1 quart every 1500 miles lol
Old 05-27-10, 06:18 AM
BarberMike
BarberMike's Avatar
lmfao
Old 05-27-10, 06:44 AM
redjones
redjones's Avatar
I put close to six quarts in too. I do add oil every 1500 miles or so. I use Moblie 1 full syn. Some say its not necessary but I prefer it.
Old 06-16-10, 02:35 AM
Supremeg56
Supremeg56's Avatar
is the oil grade to use 5w-30 or 10w-30 and whats the real difference honestly planning on doing my first oil change on friday just want to be prepared
thanks
Old 06-16-10, 03:36 AM
mkiiisupra
mkiiisupra's Avatar
being in florida, you'll want 10w-30. 5w would only be neccesary if you were in Alaska.... well really cold places anyway. There should be a graph in your owners manual
Old 06-16-10, 08:47 AM
link13
link13's Avatar
Wow, are you guys leaking oil or burning it? I am down about 1/2 quart after 4,000 miles and I do a change then. 5.4 quarts.
Old 06-16-10, 06:33 PM
suprawhite
suprawhite's Avatar
Originally Posted by BarberMike
lmfao
Me too
That was the same case with my old 85 Celica Convertible with the 22RE engine, but that sucker last forever with the exception of the valves rattles as if I was driving a diesel.
Now back to the post, I think the 2JZ used up to 5.5 quarts, but just put in 5 and check your dipstick just to make sure and add more if necessary.
Old 06-17-10, 09:35 AM
mkiiisupra
mkiiisupra's Avatar
again. The manual from my 94 says 5.4 or 5.7 pending on the size of the oil filter. Toyota makes 2 size filters. TRD also makes a new filter the size of the smaller OE filter. I get the bigger one and use 5.7.
Hardly ever burn up oil though. In the 5 years of owning it, I think theres been 4 occasions of having to add a little bit. But I've since done alot of maintenance and its been fine
Old 06-17-10, 08:16 PM
Supremeg56
Supremeg56's Avatar
cool thanks guys 10w-30 for me it is should be relatively easy anyway
Old 06-19-10, 12:20 PM
GS Nemesis
GS Nemesis's Avatar
Im curioua has anyone used royal purple?
Old 06-20-10, 01:46 PM
tuner79
tuner79's Avatar
I know people that use royal purple. Worth the $ if your into performance. Otherwise expensive. If not a performance person then stick with synthetic. I prefer a 50/50 mix myself.
Old 02-11-13, 08:12 AM
bullet5000
bullet5000's Avatar
You burn oil like I burn Grilled Cheeses
gebo
07-27-15 05:00 PM
crwys
07-26-14 01:21 AM
irokdastar
07-28-11 03:51 PM
GSLEX
RX - 3rd Gen (2010-2015)
19
02-06-10 08:54 AM
joedaddy1
04-08-07 08:34 AM
Quick Reply: Oil change.... 5, 5.5 or 6 quarts?
