Florida is300 swap guys/whoever else has some input
I'm pretty sure you have a valve body upgrade and it shift pretty hard even when barely on the throttle.
I am doing NA-T just fyi it is faster and cheaper and the stand alone isnt all that bad I used a Pro-EFI and took my tranny out and upgraded the valve body. its not done or on the road but so far im only set back a few g's and pretty much done. just figured id put my two cents in
agreed x100 as i just finished a true na-t build on one which did 415@only 15psi on a old school precision sc61 turbo .. aem was tuned to perfection by alpha and the car behaves like a stock is .. it drives the same everyday and we have full control of vvti .. car could have made closer to 450 but we were concerned about his w55
I am boosting my IS soon and I am going GE-T cuz It's cheaper. But I honestly want to know how safe am If the bottom end is stock.
I Live in Pensacola, FL and theirs barely any IS300's out here, I am a Lexus FanAddict
I have a friend with a 2002 is300 it's a manual car already. We have a aristo motor for it How do you wire it in I k ow you have to use both ecu. 8 can't find any info about the wiring
