Tech support post your question here...
#46
No, the GTE bolt pattern is different than the GE. If you really wanted to I guess you can Fabricate one using the GTE top and weld it to the GE runners but I don't think it would be worth it. There's some aftermarket ones that were made for the GE; Hypertune, Virtual Works, and FSM. There's even some people over on the Supra forums that have designed their own from scratch...Good luck!
#47
Key won't come out of the F****n Ignition!!!!!
I got one for u guys....my dam key will not come out of the ignition!!!
It seems to be locked and the only way to get it to turn to release is if I disconnect the battery terminal, if I put the key in its stuck again...This started yesterday and I never had any issues like this before. The car starts up fine and drive, no issues there.
I searched the forum and found similar threads about the issue but it can be multiple things from what I read: the ignition cylinder? Lock cylinder? I dont want to spend unnecessary money..I did everything and more from the other threads: Making sure the car is engaged in park, turning the steering wheel every way possible, Wd4, and nothing.....Can you Gurus help on this one????
#48
Help Sean..
#50
^^^ LOL thanks. I haven't had to mess with SC 400 lock cylinders ,but I have messed with other designs before. Usually there in a 2 piece setup one where you insert the grooved part of the key. The the other half is the plastic ignition which fires the car up. To gain access to that you need to removed the plastic covers under the steering wheel. Its mounted to a bracket I think you can take it out in 2 pieces. It sounds like lock piece is staying engage cause there is power being applied to it. Here is a picture for what you will be looking at. If I can look at one in time I can tell you the rest. Is the key that you have aftermarket by chance cause those sometimes don't work if one was freshly cut.
http://img83.imageshack.us/img83/153...nder0051it.jpg
#51
#53
Don't waste your time with this N/a to tt head. The main differences is there are more parts for TT then there are for N/a. just stick with what you have and go boost. ARP studs are all the same.
#54
Guys I think the members of CLFL are pretty damn awesome .It's cool as hell how we as a combined member base can truly pull together and help one another out..I'm Proud to be a member of a community like this..
#56
I haven't removed one of these before ,but I have a clue. Once you remove the covers where the lock is see if you can pull the back section out of where the key goes into. If it is one whole piece that cannot be separated your probably going to have to go to the dealer to get a new lock cylinder. If I can get to one that I can take that section apart I'll let ya know.
#58
^^^ You can put a resistor in the o2 sensor circuit not sure which wire(s). I don't know the resistant value your going to have to search around for that. I have also heard of o2 simulators ,but I am not sure what is invovled with that.
#59
I was thinking to leave it plugged in.I just want to use the whole on the pipe.without having to make another whole.I'm not on boost.I know the wide band goes on the downpipe.
#60
