ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Gas inlet loose?
Old 06-26-15, 08:51 PM
zes
zes's Avatar
Default Gas inlet loose?
I have noticed something peculiar about my 14 300h. The gas inlet (the opening into which one inserts the gas pump nozzle) appears to be loose, I think. I don't know how to describe it, every time I insert the gas nozzle, the weight of the nozzle seems to push it down about 1/4 inch. I have never seen this in any of my previous cars from multiple manufacturers. Ever. In all other cars the gas inlet appears to be rigidly attached to the body of the car, so the weight of the nozzle does not move it. In the 300h the gas inlet appears to move slightly (about 1/4 in relative to the car body. Has anybody else noticed it? I am due to get my oil changed and can bring it up to the dealer if nobody else noticed this. For now I hold the nozzle and do not let its weight push the gas inlet down.
Thanks
Old 06-27-15, 03:25 PM
airgas1998
airgas1998's Avatar
All i can say is moving 1/4" isn't anything to worry about.
Old 06-28-15, 01:54 PM
Dave Mac
Dave Mac's Avatar
I think the gas inlet tube just kind sits in some rubber gaskets/or bushings for the most part. If it wasn't able to move a bit I would be more likely to fracture.
But confirm with dealer.
Dave Mac
Old 06-28-15, 04:04 PM
zes
zes's Avatar
In all other cars it seems to be firmly attached to the body of the car. I am afraid that if I let the weight of the gas nozzle push it down, eventually there may be a crack at the location where this tube is attached to the tank.
Old 07-02-15, 03:49 PM
SLH
SLH's Avatar
I bought fuel today, and took a good look at the fuel inlet. The inlet is mounted in a black flexible gasket (looks like neoprene). The mounting gasket has a little give, so it moves slightly under force. The use of a flexible mount is a common strain-relief method. It prevents metal fatigue or over-stress that might occur with a metal-to-metal mount.
I am pretty sure that the engineers designed this thing with at least a 400% safety margin, and qualified the materials for exposure to petrochemicals. They know while designing fuel systems that any failure will be unsafe, and will certainly be very costly for the company... So they over-design to make sure that it will not fail. I'm not going to worry about it.
Old 07-03-15, 09:34 AM
LexBob2
LexBob2's Avatar
Both of our cars (non-Lexus) flex a bit and have a gasket as mentioned in SLH's post.
Old 07-03-15, 10:03 PM
zes
zes's Avatar
Thanks all. I will stop worrying about this and find something else to fret about.
Old 07-04-15, 10:44 AM
Arty101
Arty101's Avatar
Yep, all normal. My 3 Lexus's all have a little flex and movement at the filler neck.
09-25-17 06:25 AM
ShunDoe
02-25-16 05:45 AM
OCLEX03
09-12-10 09:43 PM
OCLEX03
07-29-10 09:37 PM
RON430
09-07-05 12:20 PM
Quick Reply: Gas inlet loose?
