ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Fuel Reading
Old 05-11-15, 06:55 AM
rd77
rd77's Avatar
Default Fuel Reading
Hi all,
I recently purchased a 2013 ES 350 (CPO). I've run the fuel down to empty where distance computer indicates 4 miles left, yet when I fill up the thank it only takes 13.5 - 14 gallons. I have run the fuel down to E multiple times to see if it was an anomaly, but same result. I have yet to fill up more than 14 gallons, yet the specs indicate 17 gallon tank. Has anyone had similar issue?
Old 05-11-15, 07:01 AM
Mike728
Mike728's Avatar
Welcome to a Japanese car! (and the forum) There are a few threads related to your observation. My wife's CR-V is the same, too.
Old 05-11-15, 07:19 AM
vimal01997
vimal01997's Avatar
You didn't use up your reserved fuel. The car still goes a couple miles after your distance till empty is 0.
Old 05-11-15, 07:29 AM
rd77
rd77's Avatar
So the car has 3 gallons of reserve fuel and can go another 60 miles when it indicates 4 miles to zero? My Mazda CX-9 is pretty accurate. When the dash indicates 10 miles left, i fill up close to 18 gallons on a 18.5 gallon tank. I've called the dealership and waiting for a response.
Old 05-11-15, 07:59 AM
Dave Mac
Dave Mac's Avatar
Welcome to the forum.
I wouldn't be running the tank that close to empty. Your gauge is about as accurate as any car.
Dave Mac
Old 05-11-15, 08:53 AM
Mike728
Mike728's Avatar
Yes, people have gone over 60 miles past 0.
Old 05-11-15, 08:57 AM
Mike728
Mike728's Avatar
Dave Mac
I've owned several car's over the past 35 years, only two Japanese. These are the only two that have exhibited this issue. It appears it is also a new phenomenon for the OP.
Old 05-11-15, 11:39 AM
bc6152
bc6152's Avatar
Received 1,306 Likes on 909 Posts
I look at it as a benefit not a negative. I never go below 1/4 tank anyway...Story from when I was a teenager is that sediment lays on the bottom of your tank and could be pumped into the fuel line if you go to actual empty.
Old 05-11-15, 02:14 PM
Arty101
Arty101's Avatar
Your fuel pump is probably at the bottom of the tank and gets cooled by the fuel and easier to prime. Best to have a few gallons as reserve for those reasons.
Old 05-11-15, 11:25 PM
PirelliRC
PirelliRC's Avatar
You can get about 60 or more miles once the indicator hits 0, however as Arty pointed out, its good to always keep about 3 gallons of fuel in the tank for a handful of reasons. With mine being a hybrid, this is particularly so. If ran my tank too low it can severely damage my vehicle. I for one make it a rule of thumb to fuel up when i have 50 miles left on the indicator or right when the light goes on.
Old 05-12-15, 02:45 AM
Poppa
Poppa's Avatar
Heard the same thing when I was a kid... don't know if there's any truth to it, but none the less, I still fill up around a 1/4 tank.
Poppa
Old 05-12-15, 08:51 AM
mspearl95
mspearl95's Avatar
This is how I feel too. I'd rather have reserve in the tank, then actually run out of gas when the indicator gets to zero. I've always owned toyotas, so I've never really thought twice about the car NOT doing this. Always happy to know there is still a bit in the tank when the yellow light comes on.
Old 05-12-15, 10:44 AM
Arty101
Arty101's Avatar
Like Dave says, you'll need reserve for the hybrid least you'll need to have the dealer jump start your car and maybe some damage if the traction battery gets too low.
flotus1
CT 200h Model (2011-2017)
05-21-19 09:18 AM
arf1410
NX - 1st Gen (2015-2021)
05-08-19 05:14 PM
TominBoise
RX - 4th Gen (2016-2022)
08-22-17 11:42 AM
sdrob
01-17-17 02:31 PM
foup
IS F (2008-2014)
08-31-08 08:04 PM
Quick Reply: Fuel Reading
