A Fresh Tint and Swapped Wheels!
I dont know im not a fan of Michelins even though they cost more. They came on the 2014 GS 350 i had and road noise was loud and it was a bit bumpy. After i installed the Pirellis P7s, the noise went down drastically and was much more of a better ride. I saw that they make P7 All Season tires for stock 215/55/R17 set up the ES comes with, so my next tires will definitely be Pirellis.
Most recently I had a set of the Pirelli P7 Plus put on my old 03 ES I gave to a family member to replace an aging set of Primacy MXV4. I did not find the Pirellis any smoother or quieter, pretty much the same...which is still excellent. Road noise you may hear vs your GS is likely due to that GS the Michelins
You may find as I did that the ES in general is a little less shielded from road noise than the GS, especially the hybrid when the ICE isn't running.
My point is, I wouldn't go to the expense of replacing those Michelins with the Pirellis until they're worn out (40-50k miles)
I don't think you will find that the Pirellis are any quieter than the Michelins on your ES. The GS had the Primacy MXM4 which is a little sportier grand touring tire, while the ES has the Primacy MXV4, I've had many sets of them on the ES and other cars. They are very quiet and smooth.
Yeah I would definitely buy the P7s over the Michelins. Just as good a tire for less money.
Car looks good, wheels are a big improvement. I hate the hybrid's wheels...
The Primacy MXV4 has a wear rating of 500, which is okay, but not great. Because of the greater initial tread depth, some of the Michelin competitors' tires have wear ratings between 640 and 720 (and very similar ride quality), which translates into significantly more miles of use before the tires need to be replaced.
Thanks, my goal with the ES is to blend in and not bring attention to the car, did you end up swapping the tires you got a few months ago or did you end up kepping them ? They were Hankoks or something right ?
