Cleaning the interior
HI
I have a lite tan interior .
I have scuff marks created by my shoes on the plastic interior pieces.
I tried cleaning it with soap and water, and windex.
Neither seemed to work.
What are you using to clean your car ?
A Magic Eraser( used VERY gently) for marks you can't get out with normal means on the threshold should help. Follow it with some sort of protectant like 303(non-gloss is best, I think) to give a little sheen and some prevention.
Try using a little tire shine, not wheel/rim cleaner. Tire shine doesn't contain any harsh chemicals that can damage the plastics and materials of your car. I use it mostly on bug and road grime. It should remove the marks. I wouldn't put it on the leather and/or trim panels. It won't damage them, but it will be a pain to remove.
If all else fails, elbow grease will get it off.
I highly recommend it as a cleaner for light colored interiors.
Bc, do you have ventilated seats? If so, does the ultima get into the holes ? Getting some color transfer from jeans, and want to take it off.
I think that's where I got it.
409 might remove the scuffs, but might also remove the finish Art. I can't remember who it was, but one of the guys recommended the Ultima Gel shampoo and it works great.
Yes, I do have ventilated seats. The solution is creamy and using it sparingly prevents any saturation. It takes the blue stain out perfectly. Costs about $20.00 online which, to my knowledge, is the only way to get it. Check out www.autogeek.com
JForce
Automotive Care & Detailing
02-11-11 05:11 AM
gregcarey
08-27-07 06:15 PM
