ES - 6th Gen (2013-2018) Discussion topics related to 2013+ ES models
Humming at back of the car.
Old 05-14-13, 07:12 AM
bigblack06
bigblack06's Avatar
Originally Posted by LexBob2
As I recall, there is something in the owners manual about (humming) noises when the car is shut off and that it is normal. It's the fuel system purging itself periodically.
And as mentioned, the HID's make a humming sound too.
Yep, that's what it is. My GS does it and my mothers X3 does it as well, its normal there was a discussion in the 3GS forum thread on this. I'll see if I can find it.
Old 05-14-13, 07:19 AM
jim256
jim256's Avatar
Originally Posted by IS350atWOT
Good to know. Maybe it starts only after its been parked over a certain amount of time?
True. Something like 8 hours, actually.
Old 05-14-13, 07:32 AM
Tuanle
Tuanle's Avatar
I've had my ES350 for a month, but haven't noticed any noise when it's off. How long does the sound last after it starts?
Posted from ClubLexus.com App for Android
Old 01-15-15, 09:13 PM
mgm1247
mgm1247's Avatar
Default True
Originally Posted by jim256
+1, It's a fuel evaporation leakage check, have had the sound on other cars but this one runs a little longer than the others.
Yes. This gentleman is correct. I bought my IS250 2 weeks ago. Heard the noise. Called the dealer. Evaporation leakage test. Normal. Hurts nothing on car. No drain on battery. Same power consumption as a wristwatch they say. Enjoying the car. But I wish I had the bucks for the FSport.
Old 01-16-15, 06:19 AM
Freds430
Freds430's Avatar
Received 1,158 Likes on 748 Posts
Heard the same noise from my wife's RX350. I was really baffled until I came in to read this forum. It is the fuel system. You would think every salesperson would tell buyers of this noise. It is in the manual but who reads that cover to cover. Thought I read it only does it when the tank is a 1/4 low or only has a 1/4 of a tank left.
Old 01-29-15, 08:13 PM
grabilsm
grabilsm's Avatar
I too heard this sound about 5 hours after the car was turned off. I did have 1/4 tank of gas so I am assuming its the vapor pump. Did anyone confirm this is normal on the es350 with the dealer because in the manual it says it only applies to hybrids.
Old 01-30-15, 05:44 AM
Mike728
Mike728's Avatar
Yes, it's very normal.
Old 01-20-17, 08:00 PM
telseg
telseg's Avatar
Default Glad I found this
I walk into my garage and hear this humming coming from the car. It had been hours since I had driven it. After a couple of minutes of trying to figure out where it is coming from I finally pinpoint it coming from rear of car underneath. I get my key and power on the car to run through the System Check. Nothing unusual comes on the dash that would indicate a problem. I shut down the car and the noise is gone. Very odd.
Old 01-21-17, 08:01 AM
Mike728
Mike728's Avatar
Originally Posted by telseg
.... Very odd.
But, very normal.
Old 01-22-17, 12:50 PM
jollick
jollick's Avatar
I believe it has to do something with the fuel vapor recovery system. This is normal and I also have experienced it.
Old 01-22-17, 02:38 PM
lesz
lesz's Avatar
Received 1,017 Likes on 695 Posts
Not only is it normal, but all of our cars do the same thing, and they are all supposed to do it. It is just the case that many are unaware of it happening because it happens well after the car has been shut down, and, unless you happen, by coincidence, to be in the garage when it is happening, you wouldn't be aware of it.
wickedt
12-26-23 12:29 PM
GS42NV
07-06-07 06:59 PM
RA40
12-30-05 09:42 AM
verylost
SC- 1st Gen (1992-2000)
02-18-02 10:46 AM
Quick Reply: Humming at back of the car.
