ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
tpm's warning light on
Old 03-02-15, 06:05 PM
ThumperPup
ThumperPup's Avatar
Default tpm's warning light on
TPM's warning light on
hi i was wondering is the reaosn the TPM's warning light is on because i don't currently have a spare tire in the turnk i have the tire i mean but no wheel. and the snesor is just sititng in my glove box untill the new wheel comes in.
is this the reason why the warning light is on ?
do all 5 sensors have to be registered or can i just have 4 of them on so that it doens't need to pick up on the 5th that doens't have a wheel ?
thanks
Old 03-02-15, 10:34 PM
xanderES
xanderES's Avatar
Stock setting has all 5 sensors in the system. Thats why the light is currently on for you.
Not sure. Never heard of anyone going through the trouble of trying to de-register a tpms sensor since there's a spare tire in the trunk.
It might be possible. Not sure if the system requires a static 5 but you'd have to have a tpms programming tool to do it anyways.
Old 03-03-15, 03:36 AM
ESh
ESh's Avatar
I think there's a way to disable the fifth sensor. I have the spare which doesn't have the sensor inside but next to the wheel I have the TPMS scanner which is disabled.
Old 03-03-15, 04:49 AM
ThumperPup
ThumperPup's Avatar
ok thanks guys
ill just spend the cash on a new wjeel a little earlier than i jad wanted to
i got run off into a curb the other day
and it not only bust the huge chunk outbof the wheel but also bent my passanger side control arm so i just spent like 1000 to fix the car was trying to avoid spending another bit on the wheel for now but guess i cant do that
Old 03-03-15, 11:55 AM
xanderES
xanderES's Avatar
If you're really looking to not spend anything you can make a pressurized cannister out of pvc for a couple bucks.
https://www.clublexus.com/forums/is-...pipe-bomb.html
Dont let the name scare you.
This works also if you're running aftermarket wheels and cannot mount the tpms.
oldteacher
12-08-18 05:18 AM
kwik801
11-25-13 07:31 AM
lambie
07-17-12 06:17 AM
HTSHOW
05-03-12 02:14 PM
ByoungWoo
08-27-08 03:09 PM
Quick Reply: tpm's warning light on
