ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Garage door remote program problem
Old 03-30-14, 08:13 AM
harmonytom
harmonytom's Avatar
Default Garage door remote program problem
Have problem to program my 2010 E350 remote after changed my garage opener from Genie to Chamberlain. Tried several times as shown in Lexus' how-to videos, but didn't work. It had no problem at all when I had the car remote programmed to Genie garage opener 2 years ago. Anyone has any idea or suggestions?[/B]
Old 03-30-14, 08:52 AM
LexBob2
LexBob2's Avatar
I seem to remember in the past, owners having luck calling the Homelink number for a fix or walk through. It seems like it's probably an easy fix. Is there anything in the owners manual that might help? I usually keep the manual handy when setting up the garage door opener.
Old 03-31-14, 09:27 AM
driven905
driven905's Avatar
It is in the user manual. I used it to set mine up. It's possible that all the buttons are pre-programmed and they need to be cleared first before programming a new garage door opener.
Old 03-31-14, 09:36 AM
Rogarven
Rogarven's Avatar
I had a hard time getting mine reprogrammed . I wondered if it was because of the "rolling code" on in the garage. I gave up and use the remotes that come with the unit. I did the same thing with a Cadillac I inherited.
Old 03-31-14, 03:52 PM
jagtoes
jagtoes's Avatar
The system works for rolling codes. You need to clear/delete existing codes and park the car as close to the door opener as possible. Then follow the OM and it should work without any problems.
Old 04-01-14, 03:57 AM
harmonytom
harmonytom's Avatar
Thanks everyone here. i finally did it. what i had to do was to re-program the remote, and program again.
Thank you all!
golfkwesi
01-30-17 10:28 AM
ownerrx350
RX - 3rd Gen (2010-2015)
28
12-21-14 05:29 PM
kevenhang
07-10-11 10:05 AM
LudeNsoL
02-28-10 01:48 PM
mamono
07-29-08 08:17 AM
Quick Reply: Garage door remote program problem
