whistling under load
I've been noticing this and was curious if anyone else has the same thing.
When accelerating usually from a stop and more noticeable when cold, I hear a whistling that seems to correspond to engine speed. If the engine isn't under load, i.e. idling or cruising, I don't hear it. It seems to be coming from the front driver's side somewhere, I haven't had a chance to get under the hood and see if there's a leaky coupler in the airbox or something to that effect.
Doesn't affect driveability, just kinda odd.
Not an expert, but I would be thinking a pulley on something.........That would be my first guess. I wouldn't imagine that you would be hearing intake noise to the tune of a whistle on a naturally aspirated car......especially on the ES being as quiet of a cabin as it has a reputation of having.......but again, not an expert.
I noticed this also in my 08 only when engine is cold once it's to its operating temp the noise goes away? I want to know what it is also
Posted from ClubLexus.com App for Android
My car went in for a coil and 6 plugs, which required removing the intake manifold. I noticed that now, after that was done, I don't have the whistle anymore. I'd say that since it goes away at temp, that's the metal and plastic expanding and sealing a leak at the base of the intake manifold. Pull it and either get a new gasket or seal it with silicone gasket maker. Also check your intake pipes from the airbox back to make sure they're not leaking.
