Minor Sidewall Gouge
I recently went to pick up my 2008 ES350 from the garage that I use for most ongoing maintenance. When I arrived, the mechanic informed me that I had a serious problem with one of the wheels he had just rotated. He pointed out a very small gouge in the sidewall next to the rim of one of the tires that he had rotated to the rear of the car. This gouge is no more than 1 or 2 milimeters deep and maybe 3/8 inch wide. Whatever hit the tire had done so at about a 20 degree angle so that there was a very small flap of rubber over the gouge He told me that this was very dangerous and pointed out some small specs of white material inside the gouge. He said that this was the cord of the tire and that if I continued to drive the car, especially at highway speeds, I could have a blowout. Replacing this tire would require also replacing the one on the other side of the car at a cost of over $400 for the same quality (rated for 50M miles)
Interestingly, when I got home and examined the gouge again, I could see no white material. I began to wonder if my mechanic caused the gouge and after I drove home, the tiny visible specks of cord were sucked into the rubber. I decided to get a second opinion. I took the car to a high end garage that specializes in Lexus and other Japanese autos. The seasoned mechanic at that shop told me that the gouge was too small and shallow to be concerned about.
I am posting this to share this experience and maybe to get any additional input.
I agree, any gouge in the side of a tire is serious and you should at least have the tire dismounted at a tire shop and checked for internal damage. It would not be the first time something like this has happened at a repair shop - I'm assuming that they also were prepared to sell you the two new tires they said you needed.
Dave Mac
Dave Mac
Taking Your Advice
While the gouge is too small to be able to tell anything with a picture, I have decided to take the tire in to a Bridgestone store and see what they have to say. If the damge is too small to worry about, I might accidentally get someone who will tell me the truth. Not too optimistic about that. From what the mechanic who found/caused the damage told me, if there is significant unraveling of cord, looking at the inside of the tire at this point might not show anything. But he's no tire expert, just a cover your *** expert. And no, he wasn't in the tire business.
swap with spare
[QUOTE=sf3r8z;7486467]I recently went to pick up my 2008 ES350 from the garage that I use for most ongoing maintenance. When I arrived, the mechanic informed me that I had a serious problem with one of the wheels he had just rotated. He pointed out a very small gouge in the sidewall next to the rim of one of the tires that he had rotated to the rear of the car. This gouge is no more than 1 or 2 milimeters deep and maybe 3/8 inch wide. Whatever hit the tire had done so at about a 20 degree angle so that there was a very small flap of rubber over the gouge He told me that this was very dangerous and pointed out some small specs of white material inside the gouge. He said that this was the cord of the tire and that if I continued to drive the car, especially at highway speeds, I could have a blowout. Replacing this tire would require also replacing the one on the other side of the car at a cost of over $400 for the same quality (rated for 50M miles)
I had the same problem with a tire on my Lx 470 (which only had 1,000 miles on it......Nail very close to the sidewall....I had the tire repaired and SWAPPED it out with the full size spare....You might be able to do this if your spare is the same type tire as the four currently on your car..........
Hope this helps.............
Maintenance Moderator
That area of the tire is designed to take some damage without causing issues...
so long as there are no cords showing, continue driving as normal... it is questionable if what he saw was cords or not - definitely have an experienced tire person look at it...
what kind of tire, aside from just Bridgestone...
Really? Why would you risk your family's safety for the cost of a tire?
Have it examined at a reputable tire center and follow their advice. I understand your skepticism, but your safety and the safety of those around you on the road isn't worth it IMO.
CQRT in AZ
CQRT in AZ
Is a Bridgestone Turanza el400. Went to a Bridgestone dealer and a Discount Tire store. Had to be sure. Both told me the same as you, Mitsuguy. As I suspected, the gouge is too shallow to be of concern. As I said in my original post, it is no more than 1 or 2 millimeters deep. The Bridgestone dealer said that the cord of the tire is deeper than that.
