Help oil change ES 350
All,
When I open the Drain Filter Cap, then filter housing also come out together.
Now how do i remove the drain filter cap now? I need your help. Thanks
I find the whole drain cap process not worth the effort. I always just unscrew the entire housing and go from there.
If you never removed the drain filter cap you don't need to replace its o-ring. You don't need to do anything other than screw your filter housing back on when you've replaced its o-ring.
I am using 5w-30 for Syn-Blend for my 2007 es350. is that ok? should i am using full-syn? Thanks
fetv
ES - 6th Gen (2013-2018)
19
07-01-16 12:06 PM
