ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
transmission
Old 10-16-10, 04:05 PM
Copguy
Copguy's Avatar
Default transmission
When driving my car with engine/trans cold, it does not seem to shift smoothly from 1-2, its not abrupt, but not real smooth. Once the engine/trans are at operating temp everything is fine. Is there a service recall or does anyone have a similar problem? I have 33000miles and its a 2007.
Old 10-16-10, 05:30 PM
garsarno
garsarno's Avatar
This web site is loaded with 2007 ES350 transmission problems. Mine was replaced in 12/06 with only 1,000 miles on the new car. I would suggest taking it back to a Lexus dealership and they can check the VIN to see if any transmission work was done. I hope you have a warranty still left on your car.
Old 10-16-10, 07:55 PM
Lexus 1
Lexus 1's Avatar
I have an 08 that behaves exactly the same way. It's a little annoying (especially for a Lexus) but I just assume it's a minor design flaw with the trans. It's behaved this way consistently since new. Otherwise I have had no other transmission issues such as the flares that have been discussed.
Old 10-16-10, 08:38 PM
RJTaylor
RJTaylor's Avatar
My used 07 (52.5 k km) had the 3-4 flare (so called), just gave me an occasional push in the back under slow steady acceleration. Dealer re-programmed the TCM (transmission control module), and no more problems; beautiful smooth transmission.
Old 10-17-10, 05:33 AM
Copguy
Copguy's Avatar
My vehicle is still under warranty until 100,000miles. I purchased an extended warranty for my vehicle. I am making a small list of complaints with the vehicle so I can get most of it resolved with one visit. BTW, was the new car factory warranty 3-36000miles or 4-50000miles?
Old 10-17-10, 06:04 AM
pestleman0
pestleman0's Avatar
Make sure to get video if the problem is intermittent. Otherwise, you will get the infamous "performing as designed" if they can't reproduce the problem. Good luck. I still don't understand the concept of having a known problem replaced for free even if it is out of warranty. For example, a window or any other part goes out at 80,500 when it should have lasted typically around 180,500. If it is a known defect in the past then I shouldn't be financially responsible for a poorly designed product whether it is in warranty or not.
Old 10-17-10, 08:03 AM
LexBob2
LexBob2's Avatar
You can go online at Lexus.com, type in your VIN (you have to sign in first), and see what work was done on the car at a dealership. This may show you if any tranmission work was done previously.
Old 10-17-10, 04:13 PM
Copguy
Copguy's Avatar
I logged onto the site. No trans problems, however, the following are listed:
1730miles-steering whl/main shaft
32177miles-9lh oil hose
Does anyone know what these are?
Old 10-17-10, 05:21 PM
LexBob2
LexBob2's Avatar
There was a recall or a service campaign, I don't recall which, for the VVTi oil hose which could break. It's a good thing your car was done. I don't know what the other item would be.
sutter1961
04-23-12 03:06 PM
silvertn35
RX - 1st Gen (1999-2003)
17
03-06-10 04:37 PM
swiftarrow
22
02-03-09 06:27 PM
Skeltron
16
05-17-07 08:28 PM
Delmiroc
04-21-07 02:20 PM
Quick Reply: transmission
