ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Speaker upgrade recommendation for standard 2007 ES350 (non-ML)
Old 08-10-13, 10:55 PM
  #61
KFinch
KFinch's Avatar
Originally Posted by Robert_J
For your components, replace the 6.5's with the Exodus Audio Anarchy mids.
From the looks of that, those might pose mounting depth problems. Any top mount depth that is deeper than 3 inches, or maybe 3.25, is likely to interfere with the window, even with the standard 1 inch spacers. If you use bigger spacers, the inside of the door panel has to be shaved. Also, you'll need a woofer that comfortably plays up to the crossover point, which might be as high as 4,000 depending on what component set he bought. Can those Anarchy woofers do that?
Old 06-30-14, 09:09 PM
  #62
iceblast
iceblast's Avatar
After installing a powered subwoofer in the trunk, I feel I miss the stock radio, as low quality it may be.
I want to improve the rattle in the rear deck, because I think the stock sub can put out decent bass for what it is.
Anyway to do this with a fairly easy DIY?
Old 08-19-14, 08:47 PM
  #63
tedsterb
tedsterb's Avatar
I'm new here. What kind of 4 inch speakers would fit in the doors of the 98 GS300? I was told that 6.5's fit in the doors? Do I need to get thin ones so they don't hit the rolled down window or back of the door? I'm looking to replace them soon. Is it hard to do?
Thanks.
Old 07-08-16, 01:09 PM
  #64
meyst
meyst's Avatar
Originally Posted by KFinch
Also, let me add to that long-winded post with the observation that the non-Levinson models up through 2009 used the JBL amp (I think), whereas the 2010-2013 models use a Pioneer amp. It may be that the Pioneer amp lacks some of the power of the old JBL amp.
2007 ES350 uses a Pioneer amp. (Nav system, non-ML). I just pulled mine out.
I've gone "full crazy" and decided to replace my nav-system with non-nav so I can replace the factory headunit and amplifier.
AJU72
07-29-17 05:27 AM
GL123
04-22-09 04:11 PM
blue99GS4
03-16-09 11:53 PM
ByoungWoo
05-02-08 10:18 AM
MATEOGS
02-22-08 05:15 PM
Quick Reply: Speaker upgrade recommendation for standard 2007 ES350 (non-ML)
