Speaker upgrade recommendation for standard 2007 ES350 (non-ML)
#61
From the looks of that, those might pose mounting depth problems. Any top mount depth that is deeper than 3 inches, or maybe 3.25, is likely to interfere with the window, even with the standard 1 inch spacers. If you use bigger spacers, the inside of the door panel has to be shaved. Also, you'll need a woofer that comfortably plays up to the crossover point, which might be as high as 4,000 depending on what component set he bought. Can those Anarchy woofers do that?
#62
After installing a powered subwoofer in the trunk, I feel I miss the stock radio, as low quality it may be.
I want to improve the rattle in the rear deck, because I think the stock sub can put out decent bass for what it is.
Anyway to do this with a fairly easy DIY?
#63
I'm new here. What kind of 4 inch speakers would fit in the doors of the 98 GS300? I was told that 6.5's fit in the doors? Do I need to get thin ones so they don't hit the rolled down window or back of the door? I'm looking to replace them soon. Is it hard to do?
Thanks.
Thanks.
#64
2007 ES350 uses a Pioneer amp. (Nav system, non-ML). I just pulled mine out.
I've gone "full crazy" and decided to replace my nav-system with non-nav so I can replace the factory headunit and amplifier.
AJU72
07-29-17 05:27 AM
GL123
04-22-09 04:11 PM
blue99GS4
03-16-09 11:53 PM
ByoungWoo
05-02-08 10:18 AM
2007, 350, 430, es, es350, extremecoolgadgets, extremecoolgadgetscom, infinity, lexus, sc, speaker, speakers, suspension, upgrade, upgrades
