ES - 5th Gen (2007-2012) Discussion topics related to 2007+ ES350
Best OEM tires for ES350?
Old 09-20-07, 09:46 AM
LexBob2
LexBob2's Avatar
Originally Posted by MShybrid
If I remember correctly, when I was looking at the brochure, prior to making our purchase, there was a note that discussed the short tire life. I dont have access to the brochure right now but I would be curious as to the cause of the premature wear. Is it a problem with certain brands of tires or is it something that effects all ES's no matter which tire is used.
I think that referred to the summer tires only. I believe the all-weather tires have a longer/normal life.
Old 09-20-07, 09:52 PM
350Dave
350Dave's Avatar
The short tire life is more from Lexus' legal department. 17" lo pro tires will not last as long as standard aspect tires. People get upset if they don't last 40K or so, and this sort of gives the service dept ammo to counteract any consumer complaints,
Old 09-22-07, 05:22 PM
LS4Lexus
LS4Lexus's Avatar
Lexus seems to have that disclaimer regardless of if they're using low-profile tires or not. Most of the OEM summer tires they use have low treadwear ratings (I've seen as low as 160 on the previous-gen ES).
Lexus actually replaced all the OEM Goodyear Eagle GA tires on my LS400 in the early '90s due to customer complaints about short treadlife. And I hadn't even complained...Lexus corp just sent a letter to me saying I could go to the dealer to have all my tires replaced for free. They must've learned their lesson from that and added the disclaimer.
Old 09-22-07, 05:33 PM
LS4Lexus
LS4Lexus's Avatar
Looks like I was little off on the OEM choices for the ES350. They actually are (in order of aftermarket pricing from highest to lowest):
Toyo PXJ33
(High Performance Summer) Treadwear: 220
Michelin Energy MXV4 S8
(Grand Touring All-Season) Treadwear: 440
Bridgestone Turanza EL400-02
(Standard Touring All-Season) Treadwear: 260
I'll probably go with the Toyo PXJ33 since i'm in SoCal.
Old 09-24-07, 01:28 AM
GRFE350ES
GRFE350ES's Avatar
tirerack.com comparison shows that;
GoodyearEagleResponsEdge is quieter than
MichelinMXV4S8 and BridgeTuranzaEL400-02. (but ToyoPXJ33 lacks data)
I am in SoCal too, and need your recommendations. Thanks.
Old 09-25-07, 12:59 PM
toneman
toneman's Avatar
The main reason one would want to go w/ the "summer" tires is that they generally offer better (dry-weather) road grip than their all-season counterparts. The rubber used on the summer tires have a softer tread compound that is typically not conducive to longer tread life. That's the trade-off--exceptionally-great grip at the expensive of tread life, or decent grip but longer tread life.
Summer tires aren't really needed on the ES if you plan on driving it mostly as a commuter vehicle, since it's not as if you really need the extra grip that such tires offer when driving to/from work...
Old 04-11-13, 01:20 PM
don6709
don6709's Avatar
Toyo PXJ33
I have Michelins Energy MXV4 S8. they are good tires, quiet ride. With the exception of tread life. If you get to 30 000 miles without anybody suggesstings you change it, you are lucky. Talked to Lexus cust svc. They said those tires were selected for their ride. Treadwear was not a high priority for them in selecting this tire for ES350. Just curious, are later models 09 -12 ES350 still getting the Mich Energy Tires ?? I have heard a lot of people switching to the Michelin Primacy.
Old 04-11-13, 03:33 PM
garsarno
garsarno's Avatar
My 2011 came through with Bridgestone Potenzas. Car has 9,700 miles on it and I would estimate the tires will last to 20,000 miles.
Old 04-15-13, 06:48 AM
mattds
mattds's Avatar
I have an 09 with the OEM energy's...they aren't great. they are a bit noisey on the high way, I had contiprocontacts on my vw prior and they seemed quieter and the primacy's are always great. I may go with the Turenza serenity's...they come in a low rolling resistance 225 55 r17 and the primacy do not have the LRR in that size...
Old 04-17-13, 03:57 PM
CQRT
CQRT's Avatar
Interesting that this is a six year old thread - - regardless, I have 25k on a second set of tires - -original Michelins lasted 33k miles . . current Michelin MXV4's have 27k on them and will easily go 35-40 . .
Old 04-17-13, 05:35 PM
amf1932
amf1932's Avatar
I changed my tires only because of their age, not because of the mileage..18K.
The car, a new 2007 ES350 had Michelin MXV4's installed at the factory, and I replaced them
with the same type. I purchased this car in April, 2006, so I was concerned, since the tires were on my car for about 7 years.
Old 04-17-13, 05:56 PM
nevernu
nevernu's Avatar
18k in 7 years sweet , gonna be a classic
Rhambler
12-21-15 04:05 PM
FinaLpeace
08-28-14 10:51 AM
stefnee
08-10-09 01:53 PM
richbutler
06-08-06 09:01 AM
Quick Reply: Best OEM tires for ES350?
