Camry Struts/lowering springs?
Old 04-14-03, 01:27 PM
92Es300 5sPd
92Es300 5sPd's Avatar
Default Camry Struts/lowering springs?
I am in bad need of new struts I wont be having the lexus for no more than a year from now maybe two and I dont see spending the 100 per strut from lexus. I was wondering if the struts for a 92 camry will fit my 92? any feed back will be great. Also My big o said to buy the struts and lowering springs at the same time he also said if i find out if the struts will fit form a camry he will order htme for me.
Old 04-14-03, 02:27 PM
Luc
Luc's Avatar
Yes, the struts will fit. However, you should check to see if you have serviceable struts or not, this way, all you need to change is the inserts/cartridges without having to change out the entire struts.
Old 05-14-03, 07:48 AM
eddied106
eddied106's Avatar
Hey, I got the same problem u do w/ my '92ES, where u able to fit the camry struts in ur lex? Do you know what other struts are compatible with the 92ES? thx.
Old 05-14-03, 09:55 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
It's not a matter if you're able to fit...THEY WILL fit. They are the exact same chassis VCV10. Just order strut replacement cartridges for the 92-93 Camry V6 model and you won't have a problem. They're the exact same thing.
sgvlex
Suspension and Brakes
06-05-17 11:01 AM
tkafam1
08-24-08 11:47 AM
t70 supra
11-13-06 07:00 AM
IcEnPinKi
12
03-27-05 01:36 AM
Ghetto-Pimp
26
03-02-03 01:42 PM
Quick Reply: Camry Struts/lowering springs?
