1998 Lexus ES300 Bottoms Out...Springs?
My 1998 ES300 has about 265,000 miles on it but runs GREAT. The only problem I have it that it is getting lower and lower and it bottoms out when going over almost any bump. I am assuming it is the rear springs and not struts. Is this a correct assumption? What are the best springs for this car to get is running high again and to stop bottoming out?
If you bottom out you probably need the struts too, that is a classic sign of strut/shock failure.
The dilemma you are going to have in replacing suspension...the aftermarket stuff is junk that will last maybe 50k miles and it will not ride nearly as good as the stock stuff originally did, and the stock parts are very expensive but will last as long as your original stuff did so if not another 265k at least another 150k. Think how long you will keep the car and how much you like that Lexus ride before you make the choice.
jaredmac11
28
11-20-16 08:43 AM
