Burning Smell...
Old 12-10-13, 07:55 AM
sanderll
sanderll's Avatar
Default Same thing burning rubber smell in 2003 ES300
I am experiencing the same thing in my 2003 ES300. When car is running and sitting at a light, you smell burning rubber inside the cabin. My husband has checked all of the belts and they are fine.
Any other thoughts besides replacing oil pan, gaskets, etc?
Old 12-18-13, 11:38 AM
minato
minato's Avatar
Any update or insight on this? I had the same issue last night . I cant seem to find where the smell is coming from?
08 IS250 AWD
Old 05-14-16, 04:17 PM
DIO94LS400
DIO94LS400's Avatar
i also have the same issue mines a little worse tho after about an hour or so of driving smoke will fill the car with the type of smell you described.... help please cant die driving to work
Old 02-21-18, 05:27 AM
mirekti
mirekti's Avatar
I have similar issue on 2005 ES330. A year ago my mechanic replaced engine oil pan and I started becoming burned oil smell in the cabin. It doesn't seem related, but it happened after that service.
In the meantime he replaced the engine valve gasket (I believe only the one that goes on the edge), but this didn't help.
Anyhow, I cannot see any oil leaking under the car, but when driving as if it drips very small amounts of oil that get burned on something. Also, to me, it appears to be in front part of the engine towards the license plate.
My idea is to go to some car detail shop, and let them clean the engine. The idea is a bit scary as I read many horror stories.
Would the steam cleaning be the safest way to clean it all up from the outside?
Once this is done, I am hoping I would be able to locate the source of smell.
trhs75
RX - 1st Gen (1999-2003)
06-09-13 06:10 PM
gs2impress
GS - 1st Gen (1993-1997)
07-23-10 03:58 PM
gtoden1
16
01-24-10 08:03 PM
r4z0r3ck
07-19-02 08:58 AM
LEXBERG
07-13-02 02:43 AM
Quick Reply: Burning Smell...
