2000 ES - Front Windows off Track
Old 11-04-14, 06:34 PM
funcrusher
funcrusher's Avatar
Default 2000 ES - Front Windows off Track
Is this a common problem with this generation? I owned an 02 years ago and never had this issue. I think the rubber where the window meets the door has moved around some on both doors. I'm not sure but they're both way to loud when im doing 60+ so annoying
Old 11-06-14, 05:00 PM
Hayk
Hayk's Avatar
Not sure what your complaint is. Is it simply wind noise?
Old 11-06-14, 06:23 PM
drkandre
drkandre's Avatar
I had a similar issue with mine. Window was too far forward, and angled out too far, causing wind noise. Look around on replacing the window regulator and you should find out to adjust the window
Old 11-06-14, 07:57 PM
funcrusher
funcrusher's Avatar
Drkandre is it in the dame thread?
Old 11-06-14, 09:14 PM
drkandre
drkandre's Avatar
It should be. Windows need to be adjusted with a new regulator
isam250
11-28-07 12:11 PM
1stgenGSb
GS - 1st Gen (1993-1997)
10-11-06 06:12 PM
twister
ES - 5th Gen (2007-2012)
07-31-06 06:22 PM
Booyah
11-18-04 11:14 PM
Quick Reply: 2000 ES - Front Windows off Track
