00 ES headlight bulb failure
Old 10-20-14, 11:32 AM
alohaman
alohaman's Avatar
Default 00 ES headlight bulb failure
Hi guys., I have 00 ES with built in HID headlight my problem is the driver side head light is not working, but it does not show on the indicator /instrumental panel at all that I have busted light pls. help thx..
Old 10-20-14, 12:03 PM
lostape45
lostape45's Avatar
In short, you have a burnt out bulb, there is no indicator light on the dashboard for headlights, only for taillights. You will need to buy a pair of D2S HID bulbs, should only cost you around $50 for the pair. Installation can be tricky if you haven't done it before because the bulbs are delicate but there should be instructions on the forum somewhere.
Old 10-20-14, 12:21 PM
alohaman
alohaman's Avatar
the d2s bulb can be use on my factory HID ? the dealer asking for almost $100 each on their oem bulb . can someone show me the link on how to change it?thanks in advance I really appreciate it...
Old 10-20-14, 01:04 PM
lostape45
lostape45's Avatar
Yes those bulbs are what our car uses. $100 each is a terrible price. Search on amazon and you can find a pair for $50 or less. I couldn't find any step by step instructions but this link may help: https://www.clublexus.com/forums/es3...-hid-bulb.html
Basically you have to pull out the entire headlight assembly then pull out the old bulbs
Old 10-20-14, 08:35 PM
01LEXPL
01LEXPL's Avatar
WRONG!
D2s is for projectors.
ES300 requires D2R
You're on clublexus, go to http://www.kbcarstuff.com/
Once there, look for their D2R bulbs, choose a color [I used a 5000k color series on mine], was around 60$ to my door step.
I'll tell you from experience of having used multiple brands of HID bulbs, XenonDepot REALLY puts the effort into their manufacturing & such. The quality was amazing.
Old 10-21-14, 12:37 AM
alohaman
alohaman's Avatar
thanks for your help guys ...
Old 10-21-14, 12:03 PM
lostape45
lostape45's Avatar
Yes 01LEXPL you are correct, my apologies. I received a pair with a D2S base that worked just fine for my car so that's where I got confused.
Old 10-21-14, 07:53 PM
01LEXPL
01LEXPL's Avatar
THey're the same base, yes. But one is made for a totally different application than the other.
Your D2S is causing more unnecessary glare in those reflector housings...
The "r" has a casper shield made for reflector housing HID's, ie. Early Luxo-barges such as the Acura TL. The "s" does not since its made for projector housings so it disperses the light better in the projector housing, ie. german cars like early Audi/BMW
Old 03-25-15, 11:40 PM
alohaman
alohaman's Avatar
My friend give me a D2S bulb,I know my oem hid headlight is D2R but can I use it just for now the D2S if I don't mind the glare? Anyway its free..My concern only is if I use the D2S for now , Do you think I might have a problem later on? thx guys..
Old 03-27-15, 01:37 AM
alohaman
alohaman's Avatar
I did change the oem hid bulb but the driver side still not working.dont know what is wrong...Pls. somebody help me thanks in advance..
Old 03-27-15, 10:34 AM
lostape45
lostape45's Avatar
Did you try swapping the passenger and driver headlight bulbs? Could be a bad ballast.
Old 03-27-15, 09:13 PM
alohaman
alohaman's Avatar
yeah I did but still don't: work..
Old 03-28-15, 06:59 AM
PFB
PFB's Avatar
If you didn't already, check your fuses. All of them. If all ok, than its probably your ballast for that side.
Phil
Old 03-28-15, 11:08 AM
alohaman
alohaman's Avatar
where is the location of the driver side ballast?
Mrd916
IS F (2008-2014)
01-19-13 08:12 AM
CJITTY
09-14-11 06:13 AM
Toyota_F1
IS - 1st Gen (2001-2005)
05-07-09 12:32 AM
newgsman
02-20-09 09:47 AM
superpats
Lighting
02-01-06 03:30 PM
Quick Reply: 00 ES headlight bulb failure
