P0330 came back
P0330 came back
I had a mechanic replace the Knock sensor, Wiring harness, and gaskets needed, and for 600 miles I had no problems. I used only OEM parts, not cheap knockoffs.
Today the P0330 came back. Same bank two code it was throwing the entire time. I have no idea what could be causing this problem. I'm sorry if this has been answered somewhere before, but I'm in a serious predicament. I was not expecting this problem. I need some advice on what to check, and prepare to shell money out for next.
Don't dismiss the possibility that even a brand new Lexus part could be defective.
Although a lot of work, If you get inthere again, interchange the 2 knock sensors, and see if the problem follows the sensor. Also double check your electrical connections.
