My A/C stopped blowing cold air and the A/C button starts Blinking
Old 05-25-14, 04:40 AM
RaheelAmi
RaheelAmi's Avatar
Default My A/C stopped blowing cold air and the A/C button starts Blinking
A/C stops blowing cold air and the A/C button on the temperature control panel starts blinking.
Restarting it after few minutes, it cools for 10 minutes. then starts blinking again and stops cooling.
Recharged it with freon but no luck . Please help.
Regards
Old 05-25-14, 08:24 AM
Chuckinnj
Chuckinnj's Avatar
Need more info........ Is the compresor running when it stops blowing cold air or does it shut off?
Did you check for DTCs by pressing the RECIRC and AUTO buttons at the same time?..... If so what trouble code is displayed?
Old 05-25-14, 11:01 AM
hzt30
hzt30's Avatar
Default Relay
This could be as simple as a bad A/C relay. Check out this thread:
https://www.clublexus.com/forums/es3...t-working.html
Old 05-25-14, 05:48 PM
PFB
PFB's Avatar
Chuckinnj gave you good advise. As a heads up, the three most common causes for your symptom (in no particular order) are:
- low on refrigerant (possible leak)
- misbehaving AC relay
- inoperative cooling fan(s)
There obviously are other possible causes, but these are the most common ones.
Old 05-26-14, 04:22 AM
RaheelAmi
RaheelAmi's Avatar
I dont have any device to check the trouble code. Yes Compressor shuts off
Cooling fan is OK
Old 05-26-14, 05:51 AM
hzt30
hzt30's Avatar
Default Blinking A/C light
Check out this article:
http://www.intrepidcreativity.com/re.../062002_08.pdf
Old 05-26-14, 06:31 AM
hypervish
hypervish's Avatar
Looks like his ES300 is a 2005 according to his profile, if that is true than that thread is of no use.
kent2174
RX - 4th Gen (2016-2022)
17
03-10-20 12:56 PM
LOVEMYSC3
SC- 1st Gen (1992-2000)
07-02-15 03:48 PM
airtraffic
06-05-11 09:36 PM
fooldall
Performance & Maintenance
07-24-07 01:23 PM
lexus4jess
GS - 1st Gen (1993-1997)
12
07-21-04 06:37 PM
Quick Reply: My A/C stopped blowing cold air and the A/C button starts Blinking
