Little or no volume from radio 94 300
Was wondering why my 94 300 has very little volume even turned entire way up antenna is also broken I don't know if that could be in relation to it it so has built in amp
Is that the original radio? Is the problem both on AM and FM? If you have a CD player, is the problem on cd as well?
Phil
Phil
Similar questions to PFB, what are you using when there is little to no volume? The radio? CD player? Will a cassette tape work? You've got a few areas that could be causing this, first being the power amplifier has gone out, next would be radio receiver assembly fault, and lastly it could be a faulty wiring harness. I wouldn't be surprised if it were the power amplifier since I assume the issue is with every speaker.
