2003 ES300 Valve cover gasket.
Old 02-10-14, 07:27 PM
tman1352
tman1352's Avatar
Default 2003 ES300 Valve cover gasket.
I have a 2003 ES300 which, I am told, needs valve cover gasket/s. How many gaskets are in the kit 1 or 2 ? How much should I expect to spend for such a job? Do I need to change the intake manifold gasket and the spark plug tube seals at the same time? Can anyone recommend an honest, competent tech near to Tamarac, Florida? Thanks.
Old 02-11-14, 04:42 AM
speedkar9
speedkar9's Avatar
You'll need valve cover gasket set (1 front, 1 rear) with spark plug tube seals $20 from Rock Auto.
Spark plugs are a good idea. NGK Iridium, roughly $50.
Follow this thread on removing the intake part of your engine:
https://www.clublexus.com/forums/es3...placement.html
And this thread to replace the valve cover gaskets:
Admir1015
09-23-17 09:38 AM
Roddrickd
06-26-17 08:46 PM
bizzness
22
08-21-12 09:43 PM
phild
11-28-07 10:56 PM
elscorcho
Performance & Maintenance
06-18-05 03:29 PM
Quick Reply: 2003 ES300 Valve cover gasket.
