Buying a 3rd Gen ES300 (96-01), what should I check? What are common problems?
The other thing I was worried about was the pillar-less doors.
1) The rubber getting old and breaking/tearing, causing a leak (because it rains a lot here)
2) Any potential damage from water running down the inside of the window (from unsealed windows or from water running down the inside of the window when the doors open while pouring rain).
So the video I posted is a bad idea to attempt? The difference I saw in that guys method is that the metal particulates/fillings in the pan, on the magnet & in the filter are removed before the flush. So instead of slowly recirculating & mixing old & new fluid until the % of new fluid is the majority, but leaving the old filter & shavings in the pan pushing them back into the transmission (like the flush machines do) it just pushes the old fluid out.
Ok, so if they don't have records of oil changes ever 3k (std oil) 5k (synthetic); then I should make sure the mechanic doing the pre-purchase inspection is going to check under the front valve cover; because this specific model engine is prone to gelling. And at $95 an hour I should expect it to add another $40ish to the inspection? Just want to make sure I know what to expect so they don't gouge me at the dealership.
Also, would a CarFax or Autocheck show oil changes? Or would it only show them if they were done at the dealership?
Thanks again!
Thanks again!
Generally a pre-purchase inspection does not include removing the front valve cover. It's best to have the seller's permission before having the front cover pulled off.
A Carfax/Autocheck may or may not show oil changes. It depends on which dealership/auto care facility did the work. Honestly, carfax's are useless. A lot of time accidents, etc are not even reported. But, I digress I'm getting off topic.
What the guy did in the video, is disconnect the cooler line. That's fine, and won't cause any issues as the transmission is using it's own pump to get the old fluid out.
when pulling off the valve cover gasket, is the old gasket reusable? does anything else need to be replaced if i pull off the valve cver gasket? or is there grommets or rubber o-rings that need to be replaced?
i cudve sworn i saw a member post here that he had successfully pulled off his valve cover to check for sludge and after he put everything back, a few weeks later, his valve cover started to leak oil inside ths spark plug cylinder tubes or something like that...
I changed the tranny fluid once, just a drain and fill with new gasket/filter.
If you search this forum and the net, there are more people with tranny problems identical to mine. Now with my new rebuild, I'm going to drain and refill the tranny fluid once a year.
I think getting an ES is a safe bet, like any other car it will have some issues, but less than most.
Would you let some stranger dissect your engine, with the chance that he may mess something up and render your car useless? I personally wouldn't. There are a lot of very brittle electrical connectors in that area. Then there is the risk of over torquing bolts and snapping them, or worse - dropping something into the engine.
You will need a new valve cover gasket. Honestly, it's not that easy to "just pop the valve cover" and inspect for sludge, if the car is not yours. I tried doing that before I bought the car, and the previous owner was very hesitant. I ended up purchasing the car, after being convinced that I won't find a better deal any time soon.
<ignore><10characterfiller>
perfectmax
11-03-08 09:25 PM
rgindallas
15
05-07-08 05:48 AM
sthrngent6
08-26-07 07:17 PM
