do i need this part for brakes?
did my first brake job ever assisted by my friend for my mom's car
used akebono proact ceramic pads, and brembo blank rotors
i cleaned the hub somewhat with brake cleaner but it was clean so my friend said just spray and wipre and i'm good
i did lubricate the back of the pads but i didn't lube the caliper bolts (i didn't take em off) the ones covered by the rubber dust boost, cause my friend said not to..
anyways i'm thinking of taking it off, and making sure i lube the bolts and the other little bits
but the overall brake feeling is good, a bit on the weak side, but better than no brakes.
i also bedded the brakes in somewhat, not a completely cause i didn't want to drive like a menace but they seem to work well, (i don't know if your supposed to for ceramics)
problem is this piece fell off
only 1 side had it, and it flew off somewhere and i didn't find it till later today.. is it important? should i replace it asap?
also should i bleed the brakes since i did pads/rotors? the brake pedal feel is a bit soft, not spongy, but its not really hard..
thanks for the advice and tips guys!
The wire clip is what pushes the pads away from the rotor. Did the new pads have holes for the clip to insert? The caliper guide pins that your friend said not to grease, should have been greased.
Do not use grease on caliper pins!
You need to use silicone paste! Also, you used brake cleaner on the entire rotor right? Because they come pre-coated to prevent rusting while they sit on store shelfs. You must clean that off before installing.
so i need silicone paste, not ceramic lube for the caliper pins?
well when i take em off to bleed, i'll go ahead and get some silicone grease
I feel important to point out that if you're having trouble finding where this goes back, its home consists of two small pinholes not really one either side, but more the edge (which I guess technically is the side; just clarifying) of the brake pad. It spans across the open distance between the two pads to help push them apart you should have two per rotor though. (pretty sure)
Also, the FSM for my '93 specifies a lithium soap base glycol grease for the slide pins.
You said that the brakes feel weak, not sure exactly what you meant by that, but IMO ceramics feel less "solid" and less grabby, but I love the silence and I think they perform better as well.
Not sure what hypervish is on about, but ceramic grease should be fine. The important part is you need to use a grease on brake parts that can take high heat that is usually a silicone or ceramic. I use the Permatex Extreme Ceramic Brake Grease, purple stuff, it is overkill for a street car but the only brake grease that survives on a race car.
Stick with silicone paste and you don't have to worry about that.
i just used the purple ceramic permatex i have, i bought silicone too just in case.. but i didn't use it, i think the permatex is a much better quality..
i also need to change a rubber boot any tips how?
http://www.raybestos.com/wps/wcm/con...1df63649a75f53
btw this helped me big time with the wire clips
The rubber boots are made of a petroleum product, and grease is also a petroleum product. When the two are together the grease will eat away at the rubber. Thus it will cause the pin to bind in the bore.
as stated by others, any high temp grease, brake grease, will work. not regular, of course
I have to say, I don't like this stuff. It tends to get really sticky when cold and doesn't allow the slide pins to move properly. 3M Silicone paste is the best IMO.
The clip is not the most important thing but you want to put it back on or run none on either side or your brakes will ware out really weird. Um you did right by silicon. Another thing ceramics don't grab as hard until they get hot then they'll out perform lesser pads all day long. That slightly weak feeling with always be there because at street driving temps they don't' grab quite as good but know that thing with stop from 90 to 0 with no fade a regular pad can't give you that.
