94 Es timing belt lh cam broken at pulley
So I'm driving on the freeway and my car turns off the timing belt cover is broken and the LH pulley is in tact but the cam that bolts on to he pulley is snapped any idea why a repair like this might cost or what it would take for me to do an in home job? I'll post pictures in a bit I've never heard of anything like this happening to Toyota or Lexus engines maybe the timing belt was off and caused it to snap?
Assuming nothing else was damaged, remove the old bolt and replace, do a timing belt job. You need to check if the knock pin sheered off, which is possible. If so, the camshaft itself may have also been damaged.
I'll take a picture a soon as I get home the pulley is fine imagine about an inch to the left the pin or whatever attaches to the cam just snapped off if its just a pin that connect s to the can that snapped I hope I can replace it but in which case I would still need to remove it from the cams right?
those are the pictures where it snapped? is it the pin the snapped? or is that part of the camshaft? , the other part of the pin that snapped looks like its in part of the engine but im not too sure any idea of whats going on or what happened?
Looks like the camshaft sheared off.
how much do you want for the 1 camshaft i need? also ive never done a serious engine job like this but how difficult would it be? and what would i need to do , to do the repair?
do u need whats shown in the pic or are we talking the actual canshaft under the valve cover....cuz i do have either or...and my es is aq 95 and yours is a 94 im pretty sure there compatable but im gonna double check...let me know what u actually need and ill shoot u a price
and its not that hard i just swaped a entire motor while taking apart the old one its simple youll basically need a 10 12 and 14 mm socket to take apart the whole car lol
beno
09-21-15 03:32 PM
cocora64
05-30-08 04:43 AM
