Es 300 DRL wont light up after install of new High beam
Hi guys ,
I changed my ''night light'' and now, both of my drl wont light up , looked at some fuses but they are all ok ?? what do you think it is ?
tanks
marc
tanks
marc
weird..well few things pop in my mind. Also I am assuming your headlights are not OEM HID?
1) is the new bulbs you put is the same as OEM (with correct watts)
2) Remove the new bulb and see if the DRL bulbs lit up again
3) or it just could be that your DRL bulbs are blown out. You can get a new DRL bulb and see if that works. If that still doesnt work then ya could be something to do electrically.
What happens when you engage your high beams. Does it light up @all?
Also your title says "Es 300 DRL wont light up after install of new High beam" but the circle pic is of install of Low beam. So am lost on that
BrandonIS
12-22-12 06:44 PM
johnnunez2
11-02-10 07:14 AM
