1995 ES300 ECM Swap w Camry? Help really needed.
1995 LEXUS ES300. 3.0L
My ECM is bad. It cut the fuel pump out.
My ECM's part number witten on the ECM is 89661 33440
I found one at a junk yard out of a 1995 Camry, but the part number written on the ECM was
89661-06200
I realize the part number is different, but some forurms say they interchange.
I plugged it in for fun and the car did fire up.
Does anyone know if this will work? can I use the ECM i got from the junkyard or should I find another one?
thanks
89661-06200
thanks
Re
Well just because it fired up dosent mean that its the right one.
I just want to make sure these are interchangable. I dont want to use the wrong one if its going to cause problems.
On this fourm, there is a post where someone has said they maybe thought it would, but I would like to confirm that with someone who is just not guessing.
Jump on Lexus parts and use the vin option to see if the toyota part # will work in your car.
http://www.lexuspartsnow.com/parts/l...661-33440.html
I get the lexus part numbers and go to http://www.toyotapartszone.com/ to see if they have it because it's always cheaper. It's kind of goofy for the exact same part #.
Both the part #'s above are found on the lexus site.
lumpy85
08-06-10 04:36 PM
2001, 30, 300, 95, camry, ecm, es, es300, interchangeable, lexus, parts, supercharger, suspension, toyota, vss
