95 ES300 would not run with code P1605
Old 08-25-12, 05:39 PM
breet
breet's Avatar
Question 95 ES300 would not run with code P1605
1995 ES 300, automatic
Some back ground info: I was driving this car the other day and suddenly it stop moving properly----No matter how hard I hit the accelerration pedal, it would only move extramely slow at ~2 mile/hr. The engine was on during the whole time and switching it to lower gears do not help. I turned off the car and waited for a while and it was able to run as usual. The same thing happened the next day.
The mechanic found the OBD2 code P1605, which indicates the knock control CPU malfunction. He said there are many possiblities---it could be the ECU or the the knock sensor or even oil pump. Should I just try my luck and replace the ECU?
Old 08-26-12, 12:55 PM
pauloil
pauloil's Avatar
if you're going to guess, start with the sensor. It is cheaper. Unless you have a donor ECU. if nothing else is bad, then I'd bet on the sensor in a car this old.
Old 08-27-12, 09:39 AM
breet
breet's Avatar
But my car would still run if it is just the knock sensor.
Old 10-31-19, 10:04 AM
Jlife22
Jlife22's Avatar
Default P1605
I have this same code in my car now p1605. I wanted to know if you ever found out what the problem was? Thanks for any help!
Old 10-31-19, 01:05 PM
Richardsr
Richardsr's Avatar
Replace the sensor and lift the negative cable off your battery for about 15 minutes. If your ECU is having a problem, this may help “reset” it’s thinking.
Other possibilities included in Lexus P1605 codes are:
Possible causes Air Leak in Intake System, Faulty Mass Air Flow (MAF) sensor, Faulty Engine Coolant Temperature Sensor, Faulty Fuel Pump, Faulty Throttle Body Assembly, Faulty Engine Control Module (ECM).
https://www.autocodes.com/p1605_lexus.html
Jlife22 (11-02-19)
Bobster999
RX - 1st Gen (1999-2003)
292
08-09-24 01:23 PM
NWiatrak
08-21-18 08:12 AM
acklac7
SC- 1st Gen (1992-2000)
10-25-15 06:25 PM
tyncobb
08-19-15 09:01 AM
nlc
04-02-11 03:22 PM
Quick Reply: 95 ES300 would not run with code P1605
