code P0171 (system too lean-bank 1)?
Old 04-12-11, 06:03 PM
obtainchi
obtainchi's Avatar
Trouble code P1133 indicates that the Bank 1 Sensor 1 Air/Fuel ratio sensor does not function correctly. This code will set if the heater in the sensor does not operate. The sensor is a very common failure.
irishman88 (08-22-19)
Old 04-12-11, 08:21 PM
ayroman
ayroman's Avatar
Originally Posted by angmedic91
Hmmmmmm, ok, well, appears you had the proper one replaced. Here in Calif. we have to use a specific air/fuel O2 sensor, because of the strict Calif. emissions. There are two parts numbers for the O2 sensors, one is for Calif emission vehicles and the other is for non-Calif emissions. Hopefully, you have the right one for that ES300. Otherwise, dont know why your having a CEL for the O2 sensor if you got the proper one replaced. Keep us posted and maybe you might have to take it into a Lexus dealer or find a Lexus mechanic who can diagnosis the issue right away. Good Luck.
thanks man, i just hope it won't be too late and too expensive until i find the exact cause of P1133 (with a new sensor in place). i am not sure, but with the right car specifications, Denso provides proper air/fuel ratio (o2 sensors) sensors. Another mechanic wants to replace the 1,3 and 5 fuel injectors.
Old 04-15-11, 05:56 AM
brandoe91
brandoe91's Avatar
So just making sure..U replaced bank 1 sensor 1( behind the engine against the firewall) ? How many wires were on the sensor? It should be four if it's a heated o2 sensor.I also had the p0171 and replacing all the o2 sensor removed the system too lean code.
Old 10-22-13, 07:40 AM
tattooeasy
tattooeasy's Avatar
any time you have an entire bank msifiring as in timing go to the OCV... and OCV filters... more than likely the too lean is from the misfires... or in our es300's Lexus calls them Cam Timing Valves part number 15340-0A010 and 15330-0A010...
Scraape (03-25-17)
Old 10-23-13, 03:19 PM
MikeLex
MikeLex's Avatar
Variable valve timing was introduced in 1998 for the 1999 model year. I think the op's car has no VVT therefore no OCV.
tattooeasy (07-09-17)
Old 10-23-13, 03:26 PM
MikeLex
MikeLex's Avatar
P1133 indicates slow response sensor. P1135 indicates a defective heater element.
Old 10-23-13, 03:29 PM
MikeLex
MikeLex's Avatar
Are you sure that the new O2 sensor is the Denso 234-4622 ?
Old 02-23-14, 11:50 PM
richaroo
richaroo's Avatar
checked my engine light at Autozone and the codes on my es300 1998 were:
1. P0300, P0301, P0303, P0305 (random cylinder misfire, cylinder misfire 1, 3, and 5).
2. P0171 - "system too lean- bank 1 (cylinder number 1 denotes bank 1)"
I had some recent repairs, which are: tuneup (spark plugs, ignition coil #2, ignition coil wires), oxygen sensor (bank 1 sensor 1).
i have visited several mechanics, none of them have pointed to a particular problem, basically they are trying to change most of the engine. Please share any tips that you have thx.
I know this is an old post, but did you ever figure out what the problem was ayroman? I'm having the same slight misfire on all bank 1 cylinders, but just barely enough to feel it as well.
Old 11-20-14, 02:16 PM
DeuceLee
DeuceLee's Avatar
Also am bumping this as I too have same problem misfire 1 3 5 and lean bank...hoping someone has better answers. 294k miles. Lot of maintenance done too it... runs rough.
Thanks,
Lee
Old 11-22-14, 07:24 PM
DeuceLee
DeuceLee's Avatar
Found the problem. The air inlet tube made of rubber cracked a couple inches before the throttle body. Everyone should check for this when getting this code. I feel it will be common problem in higher mileage es300's.
Jordan95 (01-24-18)
Old 07-05-17, 03:40 AM
DavidKH
DavidKH's Avatar
Ayroman,
how did you solve this problem? i have same problem on RX-300, please share me your experience. I'm trying to solve it few month already but....
Old 07-09-17, 08:13 PM
tattooeasy
tattooeasy's Avatar
This info about the change at 98 has actually been useful more than a couple times... so many thanks
ACarter
04-02-19 05:36 PM
eoph
IS F (2008-2014)
28
08-30-12 08:48 AM
O1GS43O
RX - 1st Gen (1999-2003)
19
08-15-11 04:17 PM
hoonami
28
02-20-09 09:15 AM
Quick Reply: code P0171 (system too lean-bank 1)?
