DVD Navigation Map Update - INSTALL HELP
Old 03-21-11, 06:09 PM
degilmer
degilmer's Avatar
Default DVD Navigation Map Update - INSTALL HELP
I have a 2002 Lexus ES300 with navigation and the original software. I just bought the DVD Navigatio Map Norther America Update Data Version 10.1. How do I install it? Is it as easy is eject the old dvd, put in the new and follow the prompts on the screen? Does the DVD insert behind the tip up Navi screen or in the trunk inside the Navi brain. Any advice or links to directions would be great.
More Info on DVD if it will help you answer my question:
86271-33039
464210-1670
DATA ver.10.1
It also states, "after this update your navigation system will only support map DVD version 'DATA ver.02' and later.
THANKS - Hoping to get some quick responses. Would love to get this done for my wife this evening.
THANK YOU!
Old 03-22-11, 05:45 AM
KLF
KLF's Avatar
Unless yours is different than mine, you pop out the old disc, slip in the new one. Done.
Did you check your owner's manual?
Old 03-23-11, 03:31 PM
degilmer
degilmer's Avatar
I'm a dope - it was that easy. Thanks
Old 04-09-19, 12:48 PM
Kristenhga
Kristenhga's Avatar
Default Same issue...
Did you guys have to have a software/firmware disc in addition to the maps dvd or what? I also have a 2002 lexus es300 and am trying to get the navigation to work.. I bought the updated discs off of ebay for the maps but it's saying unable to read data. Check if dvd map is correct... any ideas?
smilepak
06-07-15 09:12 AM
nyczdave
08-22-05 08:23 PM
Quick Reply: DVD Navigation Map Update - INSTALL HELP
