98 vs 95 Lexus ES300
Old 03-23-10, 06:21 PM
krb90
krb90's Avatar
Default 98 vs 95 Lexus ES300
Will I run into any problems swapping a 98 engine into a 95 ES300?
New to the board, thanks for your help.
KB
Old 03-25-10, 02:03 PM
krb90
krb90's Avatar
Are there any kind of electrical differences, computer or ignition or anything? I could use some assurance.
thanks
Old 03-25-10, 02:30 PM
ASG14
ASG14's Avatar
You'll have to change some of the acessories and the intake plenum/fuel rails. The main block and heads are the same.
Old 03-25-10, 08:50 PM
krb90
krb90's Avatar
what do you mean by accessories?
do you mean the whole intake plenum along with throttle body? i'm assuming i can pull off the '95 engine the fuel rails and everything else above.
thanks
Old 03-25-10, 09:50 PM
ASG14
ASG14's Avatar
The Fuel system is different, so ALL that needs to be swapped. The Intake Plenum, throttle body, is also different. The EGR valve (attached to the Plenum) is different. The VSV/vacuum rail is completely different. The Alternator and Compresor I think are the same, not sure on the PS Pump. Of course, you have to use your entire '95 wiring harness. Most of the engine sensors should be the same.
Old 03-25-10, 11:29 PM
krb90
krb90's Avatar
Thanks for the info
I really appreciate it.
Old 03-26-10, 08:34 AM
ASG14
ASG14's Avatar
Feel free to PM me when you do it if you need help.
igbeserk
05-02-09 08:45 PM
tdi_twist
15
06-07-08 08:27 PM
impala_man
04-12-08 06:18 PM
impala_man
04-01-08 08:48 PM
Quick Reply: 98 vs 95 Lexus ES300
