'99 ES300 brights won't turn on
Old 10-19-09, 11:19 PM
99es300
99es300's Avatar
Default '99 ES300 brights won't turn on
I just had my transmission rebuilt (for just over $1300, in case anyone was wondering)..
I don't know if it is something the mechanic did, but when I hit the brights, they do not come on. They are NOT burnt out. The blue bright indicator light does not even come on on the dash. However, when I flick the brights, the fog lights DO go off (like the should when the brights are on)..
Any suggestions?
Thanks-
Old 10-23-09, 07:27 PM
gulffishin
gulffishin's Avatar
I'd check the fuses, then start with the wiring. Make sure the high beam bulbs are not disconnected, and then follow the wires back; making sure no harnesses were left disconnected when your tranny was removed. If everything checks out then it's probably your switch.
Old 10-23-09, 10:51 PM
delta901
delta901's Avatar
check the DRL, it is on? If it is, then all wires are connected properly and most likely it is the relay.
Old 08-30-10, 09:27 PM
99es300
99es300's Avatar
Any posts out there on how to replace the relay?! I've searched a bit and cannot find anything. Thanks!
alleyboy45
07-05-17 07:01 PM
QuachmanES
04-30-09 08:59 AM
leinadmiih
10-30-07 02:09 PM
-mb-
RX - 1st Gen (1999-2003)
12-14-06 01:27 PM
NoLexNoSex
Lighting
12-14-02 03:44 PM
Quick Reply: '99 ES300 brights won't turn on
