Brake Fluid...
Old 06-23-09, 07:44 AM
mrchacon
mrchacon's Avatar
Default Brake Fluid...
which brake fluid should i buy? ..i no it has to be dot3
would a dot3 from a local auto parts do the job?
Valvoline, Wearever?
My BRAKE light on the dash is lit - i checked the brake fluid and its a little little bit under -MIN- ... so i needa add some fluid.. but which one do i buy?
Old 06-23-09, 08:09 AM
trukn1
NELOC Mod
trukn1's Avatar
Dot 3 brake fluid from a local parts store will work fine. Check your owners manual to make sure it doesn't specify that it has to be a Dot 3 fluid with a,b,c, etc. I really haven't read the manual so I don't know. I have used DOT 3 fluids from a local store in my LS and not have a problem.
Old 06-23-09, 08:11 AM
mrchacon
mrchacon's Avatar
the top of the brake fluid says "only use toyota dot3"
Old 06-23-09, 06:38 PM
steviej
steviej's Avatar
any dot 3 is fine.
Old 06-24-09, 05:38 AM
mrchacon
mrchacon's Avatar
so i added brake fluid.. and to my surprise the BRAKE light is still on... grrr! what now?
Old 06-24-09, 05:55 AM
trukn1
NELOC Mod
trukn1's Avatar
Are you sure you added enough. The reservior has a sensor which should trigger the light to go off when the reservior is full. You also may have a broken sensor somewhere.
Old 06-24-09, 06:09 AM
mrchacon
mrchacon's Avatar
wouldnt the broken sensor send a code to the check engine? i filled the reservior till the -FULL- line...
justin1203
RX - 3rd Gen (2010-2015)
01-23-16 11:15 PM
sw2oboi
Suspension and Brakes
05-23-10 11:01 AM
acenase
08-30-07 08:18 AM
SlashBecks
05-26-03 09:08 PM
Quick Reply: Brake Fluid...
